Howdy,
I purchased two of these switches for my new layout and it's my first experience with them. Both were described as new in box but look to be older stock as the date on the packaging says 2004.
My left hand switch works perfectly. No issues. The right hand switch is having some odd issues. I have a short 20 inch test section of track with both switches hooked up on either side. Since they were new in box I just plugged them in to test off track power I did check to see if the track jumper was in and it was on both but I did not look closely.
Both switches were switching fine on track power but the right hand one's lantern is not lighting up. I unplugged the switch and flipped it over. The track jumper is connecting the aux in and aux grnd and not the track jumper port. I pulled the jumper and put it the way it is in the manual and connected the track. Now the switch is not working at all. If i put the jumper back between aux in and aux grnd it functions off track power.
So I decided to try non-track power. I connected the power and ground from my transformer to the aux in and aux grnd, powered it up, and the circuit breaker tripped. I checked out the lionel support site and they said you only really need the power it from the same transformer so tried that and it worked but the other switch lights all dimmed and it would no longer switch.
all the while the switch lantern is still not functional. I did pop open the back and looked. The cherry switches are being fully engaged.
I have a ticket opened with where I purchased this to see if they can help me at all. Must be why I got them for half price :smilie_auslachen:
