Fastrack problems - Model Train Forum - the complete model train resource
Go Back   Model Train Forum - the complete model train resource > Scale Specific Model Train Forum > OO Scale
OO Scale Airfix, Bachmann Branchline, Peco, Dapol, Lima, Kitmaster and all other OO scale discussions here.
Old 03-10-2016, 09:04 PM   #1
coachb6252
Hobo
Fastrack problems
I need some advice regarding some issues with Lionel Fastback. I'm running into dead spots in the track. I did check out some youtube videos regarding finding and dealing with these dead spots. I'm looking for a simple way to check the track for power. Any suggestions?
Frustrated
coachb6252 is offline   Reply With Quote
Old 03-11-2016, 09:00 AM   #2
gunrunnerjohn
gunrunnerjohn's Avatar
Images: 3
I run this around behind an engine, and I add my track cleaning car to create drag.
MTH ASC Certified Tech, Henning's Trains, North Penn O-Gaugers, Member TCA
My YouTube Channel
Looking to enhance your TMCC Steamers and Passenger Cars?
Super-Chuffer, Chuff-Generator, LED Passenger Car Lighting Kit, LED Lighting Regulator
YLB - RailSounds Battery Replacement, Insulated Track Signal Driver Board
Old 03-11-2016, 10:33 AM   #3
coachb6252
Hobo
voltage car
Thanks...I'll check it out.
Old 03-11-2016, 01:31 PM   #4
gunrunnerjohn
Images: 3
You can just provide a resistive load and use a voltmeter. The important part is you have to be drawing current to measure the voltage or you'll never find the high resistance joints.
My YouTube Channel
Old 03-16-2016, 09:01 AM   #5
whitesock
Hobo
FasTrack Problem
Frustrated
I had some problems with dead spots. I installed multiply power runs from my transformer. Using 16 gauge stranded wire . The goal is to have constant voltage at several points of the fast track. Woodland scenes has a video on installing incline/declines. For a locomotive to make the incline will require constant voltage. Also saw this recommendations at several of locations at various train forums. It did fix my problems also.
Also, Lionel has a video about the center continuity problem. Talking about the center rail on 10 inch and 5 inch tracks. Remove the problem tracks and bend the center rail slightly to make a better contact. Both tracks will need to have the center pin bent slightly. Check the video out.
Good luck.
Bill
whitesock is offline   Reply With Quote
Old 03-20-2016, 09:46 AM   #6
gunrunnerjohn
Images: 3
What scale are we dealing with? You have this in OO, but Lionel Fastrack comes in O-gauge and S-gauge. I assumed O-gauge, but who knows.
My YouTube Channel
Old 03-23-2016, 10:16 AM   #7
KevOpelli
Hobo
Did you make this car? How about a how to fior this project? Tnx
KevOpelli is offline   Reply With Quote
Old 03-23-2016, 12:35 PM   #8
gunrunnerjohn
Images: 3
I made the car. I found the seemingly elusive AC 0-30V meters on eBay, and then build the special isolated power supply needed to power them. I used a standard LM78L12 regulator, 220uf cap, and a 1N4003 diode. That feeds this VB1212LS-1W Isolated Power Module to provide the totally isolated power for the meter. The track voltage is connected directly to the measurement pins.
This is the power isolator I used.
My YouTube Channel
Old 03-23-2016, 07:16 PM   #9
KevOpelli
Hobo
Thank you!
I appreciate the info, I'm a newbie to trains.
I did understand Some of the parts, but would not know how to put together to make it work!
I'll research the item list you gave me, thank you.
Kevin
Old 03-23-2016, 07:23 PM   #10
gunrunnerjohn
Images: 3
The hardest part is finding a suitable AC voltmeter. There were several on eBay a couple of years ago, now I can't find a one!
My YouTube Channel
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
