Stop for a bit and read this??
dialed in;
You are not the first, and won't be the last, to wonder about how to get started. There are two basic types of layouts,and DonR has mentioned both.
One, and the most common for a first layout, is what I call a "Train Setup" type of layout. Don referred to it as a "continuous running" layout. This type has ovals, figure eights, alternate cutoffs of the main loop, etc. etc. In other words, track, track, and more track. This provides many places for the train to roll, but really without ever getting anywhere, except right back where it started. This type of layout is for people who simply want to see trains go around different loops of track. It's not realistic, in that it looks and runs nothing like a real railroad. However that doesn't make it "wrong." There really is no "right" or "wrong" way to build a layout, it is simply a matter of what you want. The post "It's a start" by Riggzie in the "My Layout" section of this forum, has a track plan that's good example of this kind of layout.
The other option is what I call a "Model Railroad" type of layout. This is an attempt to model part of a real railroad, or at least something that looks, and operates, somewhat like a real railroad would.
Don mentioned switching cars, and possibly continuous running as well.
Real railroads are not laid out for continuous running. There are no figure eights, or ovals. A real railroad's "track plan" is basically a straight line, or as close to a straight line between cities, as natural obstacles will allow.
There are sidings so that trains can pass each other, and spurs to let empty cars be dropped off, and full cars be picked up, at industries along the way.
A model railroad then might hide half of the oval needed for continuous running to disguise the fact that the trains are running in circles.
There can be much more to it, so I'm suggesting you read this file (and possibly others that I have written, but only if you want them) before you go further with your construction. You may have your first "This is a mistake, I'm going do it this other way instead" moment, or you may decide "I like what I have, and I want to go on with it." That is entirely up to you.
Good Luck with whatever you choose to build, and Have Fun!
