Is anyone using an arduino-controlled S88 network? - Model Train Forum - the complete model train resource
Old 08-23-2019, 02:51 PM   #1
Shdwdrgn
Dispatcher
I'm going to get started expending my test layout to include track sensors soon and S88 seems like a decent choice for my needs. However looking around I can seem to only find a single example of arduino code from Rudy's model railroad page. This makes me wonder if there is really that little interest in S88 now, or if Rudy's code is just that good that nobody else ever bothered writing their own code?
Yes I know Loconet is another option for track sensors. The big thing that pushes me away from this is that each module needs to be specifically addressed, while in S88 each module is given an address based on its location in the chain. Since I will be working on a fixed layout, the S88 option means I can program spare arduinos which can be dropped right into place without having to flash them with an address before use. I'm open to any suggestions as to why loconet would be better in the arduino world, though, as both networks are fully supported by my DCC++ controller. The only requirement is that I can run it from an arduino nano board.
Shdwdrgn is offline   Reply With Quote
Old 08-23-2019, 06:57 PM   #2
gregc
Engineer
S88 seems dated. separate data and clock requiring a synchronous controller and Ground. What would PS and Reset be used for. These additional lines consume I/O on an Arduino.
RS-485 requires just 2 wires and is well suited for the asynchronous communication controller on an Arduino. RS-485 is used by the NCE cabbus (NCE compatible Arduino and code)
not sure how addressing becomes position sensitive unless each device needs to propagate a message not matching it's own address to the next node. Won't this require two UARTs? And won't your code need to be modified or adaptive as nodes are add/removed? I think it would be easy to simply program an address into EEPROM. Then you can add/remove nodes during development w/o requiring any changes to controller code.
yes, half duplex RS-485 code requires polling and a node will need to wait for the next poll to send. but layout accessory control doesn't require much bandwidth. (KISS)
more sophisticated layouts separate locomotive control (DCC) from accessories (C/MRI, LCC). Not sure combining control of turnouts, signals and occupancy detection with DCC++ on an arduino is the best approach. Assume you'll want a PC interface for layout control and there are inexpensive RS-485 USB adapters.
The same PC application can control accessories and locomotive thru a separate HW interfaces.
gregc is online now   Reply With Quote
Old 08-23-2019, 07:27 PM   #3
gregc
Engineer
why an nano with it's limited I/O? are you using them as nodes? or intelligent controllers?
the C/MRI approach uses unintelligent I/O nodes to do I/O and message it between the node and control application running on a PC. The PC sequentially polls each node, sending update output bits (e.g. turnout, signal states) and expects the node to respond with an input update (e.g. turnout position, block occupancy detection.
nodes would be geographically spaced around the layout to provide I/O. turnout/signals on one side of a long siding may be served by one node and the other end of the siding by a different node. Spare I/O on a node can support expandsion.
if the number of input and output bits are equal, the same code could run on each node, a different address programmed into EEPROM (via configuration msg). If unequal, a configuration message could be sent during initialization.
an MCP23017 could be added to an existing node to expand the amount of I/O it supports. Generic code could be configured to support as many MPC23017 as needed.
Old 08-24-2019, 03:01 AM   #4
Shdwdrgn
Dispatcher
The board I'm using is a "DM nano strong". It has a unique layout that allows easily plugging in things from IR sensors to servos, so I can use the same board as a DCC decoder/controller as well as being a sensor in an S88 or loconet bus. Yeah it's an older chip but as you mentioned these functions don't require much bandwidth and there's a lot of available code specifically for using the nano.
I am drawn to the simpler bus and tree-style connections of loconet, and what little I've read on it suggests that has a much greater range of features than S88. When I mentioned my objects to having to program in addresses for loconet boards I was thinking along the lines of plug&play replacements when a board fails, however it occurs to me that the DCC decoders which I also use this board for ALSO require setting an address on each unit... so that objection went right out the window. Now I'm trying to learn more about loconet or find some code I can load on an arduino to test it out, but don't seem to be having much luck on either.
And one other thought came to mind today... S88 only provides information on simple on/off switches -- an item is either triggered or it isn't. That will work for *most* of my plans, but I also have RFID tags I want to be able to read. I'm just not sure if any current bus types are up to that task, or if it would be easier for me to just send the information over wifi to the computer? However along that same thought I also wonder if loconet could handle a variable range, for instance to read the strength of a signal or the brightness of a light? If loconet is also a 0/1 state machine then I'll probably handle the variable stuff over wifi as well, maybe set up an MQTT service to track the info. What it comes down to is I just don't know much of anything about the current state of model train sensors and networks, within the realm of stuff that is open and available to create on arduinos.
Old 08-24-2019, 07:36 AM   #5
gregc
Engineer
a generic C/MRI node (poll/response) simply does bit I/O. It interfaces to separate HW to control switch machines and signals (to conserve bits) and occupancy detectors for input.
an arduino type processor has more than enough MIPS
Digitrax champions loconet. But like the CAN bus used by LCC, it supports CSMA/CD which requires not inexpensive communication controllers that can autonomously detect a collision and immediately suspend transmission.
what features interest you?
sounds like you're expect to find a library supporting communication rather than writing your own code.
i'm sure any bus can transmit as many bits as you'd like. Protocol and message type dictate what can be sent. Besides an address, a message type/size byte can be used to send different types of information of varying length.
you may need a less than generic node to measure an photo transistor level using an ADC and transmit it in a message other than a bit I/O response. (a bit can be added to a response message indicating that it is the final msg in a response). Such a msg may need to indicate which sensor the value is for.
If loconet is also a 0/1 state machine ...
not sure what you mean by 0/1 state machine. Loconet is used by Digitrax for communication between its controllers and command station.
i believe the current state is moving toward LCC (which is CSMA/CD). But C/MRI has been around since 1985 supporting layout control independent of locomotive control (i.e. before DCC).
we've often had to develop our own mechanisms for getting debug information from the embedded systems I worked on. (On one system I used a spare DAC to output echo canceller coefficients). Not only do you need something to do what the system is intended to do, but also debug it when it doesn't do what's intended.
being able to build your own tools avoids the learning curve of libraries and their limitations. Sometimes those tools are bigger than the application.
Old 08-25-2019, 02:23 AM   #6
Shdwdrgn
Dispatcher
It appears there are at least a couple arduino libraries already available already (including for the ATmega328 that the nano uses), plus some simple circuits to interface the bus with an arduino pin, so that isn't much of a problem. I'm not sure why you seem to indicate the interface is expensive?
I *think* maybe I'm starting to understand the basics of loconet. Maybe someone can check me on this?
  • Slow communications over the rails. Seems like it might be compatible with DCC, but I can't tell for sure?
  • Fast communications over a 6-wire bus. This seems to be used for everything other than throttle control.
  • Simple sensor network with 1-bit flags to indicate when a sensor has been tripped
  • I believe commands can also be sent TO devices on this bus, so for instance you could control turnouts?
  • I'm still not certain if the loconet rail sync pins are meant to connect directly to the rails, or if there's supposed to be some kind of interface between them?
There also seems to be some kind of interface for a computer, but I'm not sure yet how the state of sensors would be read. Are we talking about a closed-source protocol, or is it something simple like a telnet connection?
Still a lot of questions here, and I'm trying to figure it all out in between a lot of other work. I think my biggest concern right now is I haven't seen a compete circuit for fully integrating an arduino with loconet which is paired with any specific code library. I know there would need to be a specific interrupt connected with whatever pin is used to read the bus signal. I get this feeling this is going to be like DCC++ all over again, in that I need to get a whole system up and running before I can see if any one piece is not working, and trying to diagnose a problem on the system while barely understanding what it even does. Yeah it's probably going to be a bumpy ride, but I think loconet is probably going to be the route I take.
Old 08-25-2019, 07:16 AM   #7
gregc
Engineer
because loconet is CSMA/CD, transmission must be suspended when a collision is detected as soon as the bit recognized as an error is detected. This mean in the middle of a byte. CAN chips are designed to do this.
Not sure I understand this loconet interface. (Loconet spec). looks like SW must monitor the RX pin to detect a collision an suspend TX and reschedule transmission later when the line is idle.
RS-485 simply requires a bipolar line driver converter to interface to the arduino UART and doesn't need to deal with CSMA/CD. The Arduino does have a function to indicate when TX is complete and the TX can be disable (half-duplex bus).
I think maybe I'm starting to understand the basics of loconet. Maybe someone can check me on this?
seem pretty basic ... DCC supports communication over the rail by representing bits with timed polarity inversions. how can rails support a 6-wire bus ... as well as DCC?
As I said, Digitrax uses it for communication between it's controllers (button presses) and command station. The Digitrax command station also communicates with locomotives over the rails using DCC.
Loconet uses a common bus that nodes bridge onto or daisy chain from one to another.
by "closed source protocol" you mean proprietary? Loconet is used by more than just Digitrax
presumably the node can monitor several inputs and could (haven't looked at spec) send a message with the state of each input represented by bit position in the data, as well as receive a message to control output bits
the the link to the circuit above
so the data would be bit banged instead of using the Arduino UART?
if loconet nodes are configured to generate messages to specific addresses when specific event occur, then you should be able to have two nodes echoing data to one another.
configuring the LCC nodes seemed involved. each node requires configuration to detect some event from multiple inputs and to autonomously send a message(s) to a different node unique to the event. And the receiving node needs to be configured to accept and do something with the event message. For example, a node detects that the block has become occupied. It sends a message to a different node to set a stop signal and possibly to a 2nd node to set an approach signal, in addition to a controlling PC.
the C/MRI approach uses slave nodes that simply process input/output. A PC (Raspberry Pi) is the bus master and contains all the intelligence.
Old 08-25-2019, 12:27 PM   #8
Shdwdrgn
Dispatcher
That's not what I said, nor is that how it works. From what I've read the communication over the rails is considered 'slow' because not a lot of traffic can be passed. If it is simply using the DCC protocol to talk over the rails then that would make sense. Also the 6-wire connection appears to be carrying a copy of what's on the rails, plus two ground lines, plus two wires used for the loconet traffic. However judging from the interface schematics, both of the loconet wires are tied together, so in reality loconet is just a single-wire interface.
Essentially, yes. It doesn't look like it is a regular serial interface, so it is handled exactly like DCC on the arduino -- the Rx is driven by interrupt and the library puts together the data until a full packet is received. Tx appears to be handled by timing and collision detection. Unlike DCC, any one of the nodes can transmit data so the master controller sends out a signal when a collision is seen and all transmitting nodes reschedule their broadcast. Assuming the bit rate is pretty high, this would probably be an imperceptible delay.
I know loconet doesn't require that much processing power. The DCC++ESP32 controller I'm using supports it, which is the only reason I considered using loconet. And now that I think about it, the controller probably collects all of the loconet information and presents it through its own telnet port along with the DCC data. At least that would make the most sense, and would explain how folks are easily interfacing with a computer. Maybe I should be checking with the author of DCC++ESP32 to get a clearer idea of how this all works.
Old 08-25-2019, 12:44 PM   #9
gregc
Engineer
did you look at the link to the Loconet Spec I posted?
Old 08-25-2019, 12:58 PM   #10
Shdwdrgn
Dispatcher
Ah I did miss that. Just kind of browsing through it now, there seems to be some inconsistencies. The doc indicates pins 3-4 are +/- for the data signal, yet the interface schematic I've seen physically tie those two pins together. And it's very curious that this indicates loconet DOES use a standard serial interface. Yeah now I'm even more confused as to how it is supposed to work.
And now I'm even more confused... The only reason I considered loconet was because I thought it had been discussed on trainboard in relation to DCC++, and yet checking back now it seems like it is questionable as to whether that support was ever added. However it does look like LCC is now supported. Yeah I'm all kinds of confused...
