DIY Keep Alive - Page 3 - Model Train Forum - the complete model train resource
Old 02-25-2019, 07:34 PM   #21
Lemonhawk
Dispatcher
Lemonhawk's Avatar
Scales Modeled: HO
I think there have been several schematics posted for keep alives. Its a bigger problem if the decoder is not set up for a keep alive because the connection needs to go after the decoder signal pickoff and bridge. Using super caps may sound great but they do take some protection circuitry also. I think GRJ had something on this. Something about super caps having internal resistance.
Lemonhawk is offline   Reply With Quote
Old 02-25-2019, 08:04 PM   #22
JoeG
Conductor
JoeG's Avatar
Scales Modeled: HO scale
It may be worth it to pay the 20-some dollars to just buy it than try to save a few bucks?
JoeG is offline   Reply With Quote
Old 02-25-2019, 08:05 PM   #23
ncrc5315
Conductor
I routinely work with 24VAC at work, I can grab the two wires, one in each hand, and never give it a second thought. Last fourth of July, hospital took a lighting hit, damage several controllers on their cooling system, I'm working in the boiler room, getting hot and sweaty, grabbed a 24VAC wire to twist the wires together to land it, and got zapped, not bad, but enough to get your attention. So, yeah under the right conditions, even low voltage can shock you.
For a little capacitor fun, check out this video.
ncrc5315 is offline   Reply With Quote
Old 02-26-2019, 04:55 AM   #24
gregc
Engineer
too bad. were you just interested in saving money or learning something?
gregc is offline   Reply With Quote
Old 02-26-2019, 06:34 AM   #25
wvgca
Station Master
wvgca's Avatar
Scales Modeled: HO 1890's
Images: 42
the advantage to 'rolling your own' is that you can make it to fit some pretty
odd shapes and sizes , not available with commercial models ..
but to each thier own , after all it's gotta make YOU happy ..
wvgca is online now   Reply With Quote
Old 02-27-2019, 07:56 AM   #26
JoeG
Conductor
JoeG's Avatar
Both actually, i want to learn more about electronics, and save money.
Old 02-27-2019, 07:56 AM   #27
JoeG
Conductor
JoeG's Avatar
This is another advantage that I didn't think about!
Old 02-27-2019, 10:59 AM   #28
Overkast
Dispatcher
Overkast's Avatar
Scales Modeled: HO, currently N
I have read there are some major risks with DIY keep-alives contingent on which capacitors you choose to work with. Some capacitors tout being able to store more energy but are more unreliable and thus prone to failures (literally in firey melt-down), destroying both themselves and your loco in the process. And as such, the best advice is to stick to reputable, commercially-sold products.
But I'm no expert on this topic, so just food for thought...
My Layout: New England Model Railroad (NEMR)
Overkast is offline   Reply With Quote
Old 02-27-2019, 11:34 AM   #29
gregc
Engineer
i bought some supercaps but was disappointed when I experimented with them on the bench. They initially lost voltage very quickly before it stabilized. I assumed i just had a bad batch.
i also tried build a keep alive using 16V tantalum capacitors which are smaller than equivalent electrolytics. my engine got about 2 feet before 1 of 4 cap blew and there was a pyrotechnic display. again, i assume the caps from china came from a batch that that didn't meet spec.
just need to test well before using and verify capacitance
i have a couple electrolytic keep alives that have worked fine for years.
Old 02-27-2019, 11:55 AM   #30
Overkast
Dispatcher
Overkast's Avatar
Tantalum! Yes, those are the ones I read about that people said to use caution with. It sounded like they are desirable due to the small form factor, but extremely risky to bet on.
