Circuit breaker blows - Page 2 - Model Train Forum - the complete model train resource
Old 03-05-2019, 07:03 PM   #11
charter.pa
Gang Labourer
2 is the second from the far left. I flipped the red and black wire on the out put side of the breaker.
charter.pa is offline   Reply With Quote
Old 03-06-2019, 09:25 AM   #12
charter.pa
Gang Labourer
This problem has NOT been fixed, it moved locations. Now only breaker 2 trips when crossing into breaker 1. Breaker 1 does not trip. I reversed the output wires on breaker 1 and it didn't correct the problem. There is a new version Shinohara double crossover that connects blocks 1 and 2. The frogs are insulated in plastic and the center of the switch is also insulated. I have read up a little on these crossovers but they are Peco not Shinohara. As soon as the front wheels cross the insulated line up the middle is where it stops and trips breaker. The engine does not stall or hesitate when going thru the first frog. I am not sure if the breakers are out of phase or is the switch out of phase.
Old 03-06-2019, 09:26 AM   #13
gregc
Engineer
do you have a reversing section?
gregc is offline   Reply With Quote
Old 03-06-2019, 09:33 AM   #14
charter.pa
Gang Labourer
I do. It is not wired in yet. I still have to work on block 5 and the reverse sections.
Old 03-06-2019, 10:09 AM   #15
charter.pa
Gang Labourer
I found an article by G. Galyon covering the Shinohara. Throw all four switches at the same time eliminates crossed phase. I did this and the engine went right thru with no problem. I will wire 4 tortises to switch at the same time from a single toggle.
