2 older Atlas engines need simple decoders - Model Train Forum - the complete model train resource
Old 03-14-2019, 09:59 AM   #1
nrscroller
Gang Labourer
Hi
I have 2 older Atlas diesels that have old soundtraxx decoders in them and they just don't do well on my layout. I got these on craigslist years ago with the sound in them. The GP-38 is a dual mode and I have the original board with a 4 pin plug in it plugged into a 6 spit spot. Can I just wire that back in and it should run on DCC?
My Gp-40 I also have the original board for that and it has a a 8 pin dummy board plugged into the board in that I see, so I can just buy a digitrax decoder and plug that in for that one? I like the digitrax because they have that switching mode you can use as I run a switching layout.
Both engines are in nice shape and I would like to be able to use them on the layout.
Thanks
Bill.
nrscroller is offline   Reply With Quote
Old 03-14-2019, 11:14 AM   #2
J.Albert1949
Conductor
I just added an older (2010) run Atlas GP40-2 to my collection about two weeks ago. The light board had an 8-pin dcc plug, so I added a Digitrax DH126PS (short connecting cable) which plugged right in and the engine runs smoothly and quiet.
From the looks of it, the GP38 -does not- have an 8-pin plug, right?
Would a TCS A6x fit the GP38?
See:
https://www.trainworld.com/manufactu...adj-low-volta/
J.Albert1949 is offline   Reply With Quote
Old 03-14-2019, 11:15 AM   #3
J.Albert1949
Conductor
deleted (double-post)
Old 04-13-2019, 09:56 AM   #4
[email protected]
Hobo
Scales Modeled: HO
Atlas Decoder
Atlas may still offer simple DCC decoders that are basically replacements for the original light boards. A real simple exchange, but you should solder the wires to the tabs. The decoder number is #342.
Greg
Greg@mnrr is offline   Reply With Quote
