Under layout Sound - Model Train Forum - the complete model train resource
Old 04-03-2019, 04:47 PM   #1
nrscroller
Gang Labourer
Under layout Sound
HI
I was wondering if a person bought a say Tsunami sound decoder for diesel, can you put that under a layout and wire speakers to it and run it with a push button of some sort. I have a dcc layout with digitrax. I would think you could program it to my main zepher unit and just leave that programmed to that decoder and run with my ut4 cab. JUst a thought without having to battle putting decoders in or buying sound engines. Thoughts from anyone on this??? I am running HO scale.
Thanks
Bill
nrscroller is offline   Reply With Quote
Old 04-03-2019, 06:20 PM   #2
Andreash
Conductor
Andreash's Avatar
Scales Modeled: HO
That’s a good idea. I had thought about doing that at a railway crossing, as I just want a horn and bells at that junction. I was thinking of a mrc diesel sounder, as it is simple to install, and has many variables.
Andreash is offline   Reply With Quote
Old 04-03-2019, 09:34 PM   #3
Lemonhawk
Dispatcher
Lemonhawk's Avatar
Scales Modeled: HO
You could consist the tsunami to whatever loco your are running on the track. Just power the decoder tsunami off the track. The sound won't follow the train, but on a small layout? You could also drive larger speakers to generate better sound!
Lemonhawk is offline   Reply With Quote
Old 04-04-2019, 02:57 PM   #4
DonR
Train Master
If it's a DCC sound decoder and you want it
to be stationary, simply connect the input to
your DCC bus, give the decoder a 'spare'
address, and you can control it with your
reguar DCC controller.
I like Lemonhawks suggestion, if you have a
specific loco you want to be 'sound' simply add
the stationary decoder to a consist with that
loco. I would think it would offer the same
sound that it would if on board 'that' loco.
My only question, would the stationary decoder
need a 'load' in place of a motor?
I guess you could connect an old used motor
to it and just let it whir under the table.
Old 04-04-2019, 03:08 PM   #5
Hobbytronics
Hobo
Hobbytronics's Avatar
Scales Modeled: HO
Sound decoders are expensive just use one of these recording circuits from ebay https://www.ebay.com/itm/Voice-Recor...97.m4902.l9144
They are low cost and can record up to 2 min. You can even connect it to the speaker output of your decoder to the input of the mic jack and record your sounds directly into it.
I Design and sell Model Railroad Electronic Stuff.
[email protected] | http://hobbytronics.sytes.net | YouTube: Hobbytronics Please subscribe if you visit my channel, Thank You!
Hobbytronics is offline   Reply With Quote
