Buyer caution with Red LED's Turnout replacement - Model Train Forum - the complete model train resource
Go Back   Model Train Forum - the complete model train resource > Scale Specific Model Train Forum > S Scale
S Scale Get in here if you want the lowdown on S scale!
Old 07-07-2019, 06:09 PM   #1
BrokeCurmudgeon
Dispatcher
BrokeCurmudgeon's Avatar
Scales Modeled: N Scale and some American Flyer S Scale
I bought 10 of these along with some green lamps fro EBay. My intent was to replace the original lamps found on the turnout controllers which draw much current and get hot to the touch. I figured that LED's would work better. I still do, but out of the 10 Red LED's there were three that broke while gently screwing them into the base. They separate from the base. I still like and thing that this is a good idea but only with a better quality lamp. I may try to glue the base to the LED with super glue and see if that will work without separating. At least they are not all that expensive.
"Take my advice because I don't use it!"
Fred
BrokeCurmudgeon is offline   Reply With Quote
Old 07-07-2019, 06:21 PM   #2
teledoc
Super Moderator
teledoc's Avatar
Scales Modeled: Postwar/Prewar tinplate "O" scale
Images: 13
Super glue may be your best solution.
"MASTER OF RESEARCH & USELESS INFORMATION!!"
"Prewar Tinplate fanatic”
Newly Appointed "Tinplate Wizard"
teledoc is offline   Reply With Quote
Old 07-07-2019, 06:25 PM   #3
AmFlyer
Dispatcher
AmFlyer's Avatar
Scales Modeled: S gauge
If you have trouble finding a quality LED that looks good the alternative is to replace the 18V bulbs with 24V bulbs. Then operate the turnouts on 12V rather than 16 to 18V. This greatly reduces the current draw and heat. Not as good as LED's but way better than the original setup.
Tom
AmFlyer is offline   Reply With Quote
Old 07-07-2019, 07:29 PM   #4
MichaelE
Dispatcher
MichaelE's Avatar
Scales Modeled: HO
I agree with the super glue suggestions. That should hold the LED to the base well enough to allow you to screw it into the socket. Put a dab of silicone grease on the socket too to ease the friction somewhat.
I know screwing in some bulbs is like rubbing two sheets of 120 grit sandpaper together.
Deutsche-Bahn Eisenbahn modeling Upper Bayern, western Austria, and northern Switzerland.
MichaelE is offline   Reply With Quote
Old 07-07-2019, 07:53 PM   #5
mopac
Station Master
mopac's Avatar
Scales Modeled: HO mainly, N, S, O, G
I bought the 24 volt bulbs. The other just get too hot. Have not used them much since I have no layout.
mopac is online now   Reply With Quote
Old 07-07-2019, 08:26 PM   #6
AmFlyer
Dispatcher
AmFlyer's Avatar
Mopac, somehow I forgot you have no layout. Is it you have no layout in any scale or just no S gauge layout?
Tom
Old 07-07-2019, 09:28 PM   #7
mopac
Station Master
mopac's Avatar
I have a 4X8 HO layout. My dream HO layout was to be 15 x 24 around the walls Ho layout. No S layout, No O layout, No G layout. Oh, I do have an N layout. Small one.
Whats really stupid is I have all the lumber for a S scale layout except the plywood. Got to do it. It will be 6X14. Hopefully 4 loops to run 4 separate trains at once. Would like to have 2 loops of the K-Line 27" track.
Old 07-07-2019, 10:53 PM   #8
AmFlyer
Dispatcher
AmFlyer's Avatar
6'x14' is enough space to make a wonderful AF layout. Sounds like it is just a matter of priorities, hopefully some day in the future the S layout will make it to #1 on the list.
Tom
Old 07-08-2019, 02:25 AM   #9
shaker281
Brakeman
As far as buyers caution goes, also watch put for oil "wicks" for diesels that are merely snippets of pipe cleaners. With the wire in the middle! Not like the originals!
shaker281 is online now   Reply With Quote
Old 07-08-2019, 08:06 AM   #10
mopac
Station Master
mopac's Avatar
I am not familiar with the original diesel oil wicks. For steamer oil wicks you can use felt.
Cut to size. Might work for the diesels also.
