Its a start... - Page 3 - Model Train Forum - the complete model train resource
Go Back   Model Train Forum - the complete model train resource > Model Train Workshop > My Layout
My Layout Showcase your layout here - pictures, projects, progress, whatever!
Old 01-20-2020, 10:45 AM   #21
Riggzie
Conductor
Scales Modeled: H/O - O
ok so ive got it all laid out in anyrail - need to pay for full version, once I get something sold on ebay for $60...
this will do for now.
but now I can take it all apart and start to build a table.
then im going to get a 6" buffing wheel for my bench grinder and see if that can do well on cleaning track/loco wheels/car wheels...
gonna be a bit as the table wont be cheap and wife will say something. LOL...
Track
14062, 0 Lionel 0, Left turnout 10". (remote) 5
14063, 0 Lionel 0, Right turnout 10". (remote) 5
65500, 0 Lionel 0, Straight 10". 44
65501, 0 Lionel 0, Curve 31", angle 45º 14
65540, 0 Lionel 0, Crossing 8 5/16". 1
Total track length: 68'-7 1/4"
Riggzie is online now   Reply With Quote
Old 01-20-2020, 03:01 PM   #22
Riggzie
Conductor
just used traxeditor.com and wow easy and looks good.
im doing basics so it works... and no track piece limitation!!!!
Old 01-20-2020, 05:29 PM   #23
ErnestHouse
Conductor
Scales Modeled: O
Originally Posted by Riggzie View Post
yeah those are pretty eye sore.. other than that..they work. seem fine.
ahhh power drops. i was searching various terms like power block... power for big layouts... and the sort. will check that one now
Track is not work or doesn't work. It's how well does it transmit voltage when it does "work". Rusty pins and track make for higher loss of voltage. That means less power on the other side of that piece of track. Rinse and repeat.
Another term is power districts.
ErnestHouse is online now   Reply With Quote
Old 01-20-2020, 07:37 PM   #24
Riggzie
Conductor
so i added a power connector to far back row and far left. made it better but i didnt use the plastic/nylon pins... just supply power to all 3. nothing trips..all runs. so my question.. why does it matter to segregate power blocks?
Im just trying to learn and understand...
thx
Old 01-20-2020, 08:57 PM   #25
Lemonhawk
Dispatcher
Lemonhawk's Avatar
Scales Modeled: HO
No, however if it does short, its harder to isolate. Your lucky, with 3 rail there are no special reversers needed!
Lemonhawk is offline   Reply With Quote
Old 01-20-2020, 09:04 PM   #26
Riggzie
Conductor
appreciate it. im not trying to be difficult. may come naturally though!!! HAH..
anywho.. so if I buy isolation pins and I only do center.. that's all that is needed?
so I could break up my sections into 6 from what im seeing.
fwiw - I am having an issue. up around the turnaround, I think the 022's have the isolation pins in the wrong spot. gonna have to google that... when I have that top section added, my train doesn't want to move on closest track at all. once I disconnect that section, boom train runs....
so this look about right then?
I will run both hot to center and common to 1 outside rail - just like the utc has it...
light green/yellow is showing tracks cut - nylon pins...
Old 01-24-2020, 12:19 PM   #27
Jackets
Hobo
Scales Modeled: HO
Here is that layout in Anyrail.
I also added some extra parts that may or may not let you adjust the layout. From my tinkering a few weeks ago it seemed that if i started with more then 50 i was fine, i could not add more only use what was provided.
I also used some 65523 40" parts in place of 65500 10" parts
Also note that these parts do no line up perfectly on the second oval in the "X" i had to set a 1/8" and 5* tolerance to make them link.
I will point out that in the second oval (right side) the 2 spurs off the "X" are not accessible as it is.
Can you snap a picture or 2 of the track part in the oval with the crossover "X" and a couple of the platforms the boxcars are on. They look interesting but are hard to see well in the current pictures
Cheers,
Joe
Jackets is offline   Reply With Quote
Old 01-24-2020, 01:18 PM   #28
Riggzie
Conductor
sweet..thx gonna check it out...
yeah I was only using what I physically have as im going to tear it all apart and stack everything up and then can know what I had originally...
interesting
not following this... help me understand better?
Cheers,
Joe
I will take some pics of the X.. think I have it on my phone...
not sure what you mean of the platforms the boxcars are on.. it is just an 022 track where 10" pieces and a curve are connected...
Old 01-24-2020, 01:21 PM   #29
Riggzie
Conductor
this??
Old 01-24-2020, 01:43 PM   #30
Jackets
Hobo
Scales Modeled: HO
I have attached 2 images, one showing the platform and ramp.
The other making out the track sections you won't be able to drive a train onto from the rest of the layout.
As for the 40/10" parts its a workaround for the 50 part limit, 4 40's saves you 12 parts to use else where.
Joe
Edit: The misalignment issue in Anyrail is that it keeps things EXACTLY in line, something that can be fudged with on a layouy
