Anyone tried to put an e unit in a Burro Crane? - Page 2 - Model Train Forum - the complete model train resource
Old 02-12-2012, 06:30 PM   #11
Images: 280
The video is great but I wanted the motor pictures with connections to a rectifier or are they DC motors to begin with?
https://www.youtube.com/channel/UCkM...BLo3pJN1FGE1Gg
T-Man is offline   Reply With Quote
Old 02-12-2012, 06:40 PM   #12
Grandpa Robert
Hobo
thanks for the tip John about the Dallee, their photo shows it next to a dime so i can get a sense if it would fit, it does look small enough. I still would like to hear from someone who's done this
dallee.com/e_units.htm
Grandpa Robert is offline   Reply With Quote
Old 02-12-2012, 08:38 PM   #13
gunrunnerjohn
gunrunnerjohn's Avatar
Images: 3
Well, there's no doubt that the Dallee E-Unit will do the job, I'd just cut yourself a model of the board size and height and see if you can fit it into the shell.
Old 02-12-2012, 09:02 PM   #14
Dave Sams
Dispatcher
Dave Sams's Avatar
Scales Modeled: O and 1/8 scale
The handcar has a DC can motor. There is a small rectifier with the AC leads soldered to the frame and pickup. The DC leads then go to the motor. I removed the rectifier.
The ballast tamper had a rectifier in it, which I installed from a kit. The kit converted the AC/DC motor (universal) to a DC motor.
Here are the instructions that came with it, 20 years ago.
For $11.95, I got a rectifier and the instructions. But, I did learn how to make the conversion, and, the store owner told me how to make a converter for the transformer.
I used the largest rectifier sold at the Shack and a capacitor. The AC leads go to the transformer and the DC leads go to the track. The capacitor bridges the DC leads and helps boost the voltage.
A DPDT switch then is used between the AC/DC converter and the track to change the direction of travel.
BTW, I'm careful not to run the ballast tamper in reverse while in "tamping" mode. There are cams which would destroy the tamper action. For this reason, I did not attempt to convert the Burrow.
If you have a layout, you can keep it. If you have locomotives, you can keep them.
I'm having trouble deciding how to spend all of my Obama Care savings.
Dave Sams is offline   Reply With Quote
Tags
burro crane , e unit
