What engine pushes UP 844? - Page 2 - Model Train Forum - the complete model train resource
Go Back   Model Train Forum - the complete model train resource > General Model Train Forum Discussion > General Model Train Discussion
General Model Train Discussion Mostly anything goes, especially train related!
Old 05-11-2017, 08:46 AM   #11
highvoltage
Dispatcher
Scales Modeled: O, O27
Originally Posted by Isaac View Post
...I don't think the DDX runs anymore does it?..
Yes, it's still in operation.
https://en.wikipedia.org/wiki/Union_Pacific_6936
highvoltage is offline   Reply With Quote
Old 05-11-2017, 09:16 PM   #12
1905dave
Brakeman
Images: 8
As a former UP Locomotive Director, the engine paired with the steam engine,if there was one, was a clean new unit, or another heritage unit. That narrows it down to about 1000 possible units.
1905dave is offline   Reply With Quote
Old 05-11-2017, 09:49 PM   #13
santafe158
Dispatcher
santafe158's Avatar
Scales Modeled: O, HO, N
Originally Posted by CTValleyRR View Post
And, just for the record, steam locos are often pushed by deisels. Since it takes more than 24 hrs to bring a steam loco up to operating pressure, it is often easier to just shove it around with a diesel.
WHAT?! I don't know where you got that information but it is definitely not true, save for a few unfortunate situations.
Occasionally they'll put one behind a locomotive for extra power when needed, or to stretch out the coal supply on long distance ferry moves, but it's definitely not because of the amount of time it takes to bring a steam locomotive up to pressure, and they don't just "shove it around." The amount of time it takes to bring one up to pressure also depends on the size of the boiler. Large engines might be done in 24 hours or more, but smaller ones like what I work on can be ready, safely, in 5-6 hours.
Jake
___________________
My Youtube Channel
santafe158 is offline   Reply With Quote
Old 05-12-2017, 01:28 AM   #14
mesenteria
Dispatcher
mesenteria's Avatar
Jake, I read that comment and concluded that the poster assumed the OP was asking about shoving moves at the maintenance facility. If he did mean that a diesel takes the consist out on the main while the boiler is brought up to temperature, he's woefully mistaken.
mesenteria is offline   Reply With Quote
Old 05-12-2017, 05:50 AM   #15
santafe158
Dispatcher
santafe158's Avatar
That is a good point, and I apologize if that was the case. That is definitely true.
Jake
___________________
My Youtube Channel
Old 05-12-2017, 01:09 PM   #16
CTValleyRR
Train Master
CTValleyRR's Avatar
Scales Modeled: HO
Exactly. I'm not talking about road moves, except in one case that I know of where the steam loco was out of commission. At the Valley Railroad, we shove steam locomotives around with the diesel switchers all the time in the yard area.
And obviously, the size of the boiler will directly affect how long it takes to bring a steam locomotive to operating pressure.
Sorry if I confused anybody.
Connecticut Valley Railroad -- A Branch of the New York, New Haven, And Hartford
"We don't stop playing because we grow old. We grow old because we stop playing." --George Bernard Shaw
CTValleyRR is offline   Reply With Quote
Old 05-12-2017, 01:41 PM   #17
mesenteria
Dispatcher
mesenteria's Avatar
We're stepping from one patch of weeds to another (okay, I am...), but there is considerable variance from institute to institute as to how to fire a locomotive from cold. I have seen credible articles saying it can be done in as little as four hours to some insisting the hostler is inviting big troubles down the line if he heats the boiler to operating temperature in less than about 10 hours.
The fact is that, like diesels, steam locomotives should be kept at working temperature all the time. It isn't possible or practical, but ideally steam locomotives should be kept hot. Not long ago, diesels were left running 24/7 because to start them again was the worst thing for them.
Each 15 degree drop or rise on the stay bolts, the seals around the tubes on the tubesheets, and changes to the rivets around the boiler casings, causes stress and even minor leaks. It's especially bad for the flues. That is why the expert and skilled fireman or hostler ensures an even fire, and why the hogger does his damnedest not to spin the drivers when the engine is pulling hard. When the drivers spin, the pulsed intake of air through the gratings lifts the coal bed and much of it gets sucked into the flues. That leaves holes in the fire where now non-heated air chases the crud down the flues, but rapidly cooling the flanges and welds or seals as it does so.
To conclude, especially with older metallurgy, boilers need to be brought up to temperature over several hours. They sure as aitch would not be taken out to the main and either shoved or towed while the firemen keeps building steam and the hogger has little to do for a few hours but blow the crossings.
Old 05-12-2017, 03:24 PM   #18
CTValleyRR
Train Master
CTValleyRR's Avatar
Scales Modeled: HO
No worries -- good discussion, at least as far as I'm concerned.
You're right, though -- I'm thinking of it from the perspective of a tourist operation, where the locos are run periodically, rather than an ongoing operation where the loco would likely be needed again within a day or two at worst.
At least on the ValleyRR, the locos don't steam from mid-Oct until the holiday schedule starts up, and they go cold again from January to April. And, to be fair, we probably baby them somewhat when we start firing them in the Spring. And when they're just running weekends, they do bring in people to keep them hot through the week rather than cool down and start up again.
Old 05-12-2017, 08:29 PM   #19
santafe158
Dispatcher
santafe158's Avatar
Yeah that's a bit more understandable. We run 3 locomotives from the late 1800's, so they're fairly small compared to a lot of other places. Our rule of thumb is a minimum of four hours from cold on our smaller engine, and a minimum of two hours if it's banked and hot from the day before. Usually we try to take a little longer than that if the time is available, since it does put less stress on the boilers.
Jake
___________________
My Youtube Channel
Old 09-01-2019, 03:05 PM   #20
Isaac
Hobo
Thank you all for your answers. I do now realize that UP will usually try to throw a special unit on the back but they will just throw whatever on to provide braking not motive power. Thanks again everyone!
Isaac is offline   Reply With Quote
