It's Gettin' There - Page 2 - Model Train Forum - the complete model train resource
Go Back   Model Train Forum - the complete model train resource > Scale Specific Model Train Forum > Tinplate
Tinplate The place for tinplate of all scales, locomotives, rolling stock, accessories
Old 05-21-2019, 02:47 PM   #11
teledoc
Super Moderator
teledoc's Avatar
Scales Modeled: Postwar/Prewar tinplate "O" scale
Images: 13
Bob, The correct answer is that all original #10’s came with Cast Headlights, never strap type, that were painted Gold, at the factory. The pantograph were typically brass pantograph, but one version in “Peacock” colors had nickel pantograph. They all came with CP-8 Latch couplers, using 252-22 Coupler rivets, for mounting same. There is also a brass whistle #253-1 mounted on opposite end from the pantograph. Any question for info or parts just ask. I have Olsen’s Prewar Library on CD, for parts, and all the major Prewar Guide books in my inventory. It’s Tjcruiser’s fault, for sucking me into Prewar Tinplate, so I had to stock up on needed documentation for my own research. Just ask away, and I can usually get anyone’s answer.
"MASTER OF RESEARCH & USELESS INFORMATION!!"
"Prewar Tinplate fanatic”
Newly Appointed "Tinplate Wizard"
"The man behind the curtain????"
teledoc is offline   Reply With Quote
Old 05-21-2019, 04:04 PM   #12
rkenney
Dispatcher
rkenney's Avatar
Scales Modeled: O, O27, N, STD Gauge
The Olsen page I have shows both a cast and a strap headlight.
There are certainly a lot of punched holes for the headlights:
And to add to the confusion is this light power bar that came with the frame and motor:
I don't intend to use the lighting "track" for power, but it would be nice to know how it was supposed to hook up.
rkenney is offline   Reply With Quote
Old 05-21-2019, 04:33 PM   #13
Millstonemike
Engineer
The cast headlight will have one wire. That wire connects to the center roller collector. The headlight's other connection is to chassis ground via the body. So you need to scrape away some paint to insure you have a good ground connection. You'll see these when you have the part. Train Tender (www.ttender.com) will have these parts. Look in the link "Lionel Alpha Prewar" and search on NH-11.
Millstonemike is offline   Reply With Quote
Old 05-21-2019, 04:46 PM   #14
teledoc
Super Moderator
teledoc's Avatar
Images: 13
Bob, Olsen’s is good to see the part numbers, & it showing both types. All the paperwork indicates that the cast headlight was the proper issue. It comes down to how correct you want the finished product to appear. If you like the other type, because of appearance, then roll with it. With the power bar you show, I have never seen it, nor have I seen any documentation. Very interesting item. So far, on your project #10, it’s looking great, compared to its arrival. Will wait to see it totally completed.
Old 05-21-2019, 04:58 PM   #15
rkenney
Dispatcher
rkenney's Avatar
The cast headlights work fine for me, I just want to make sure they cover all those holes! I know the hole in the back is where the wire came through and the slot next to that is where the fiberboard insulator went.
I seem to recall a headlight on prewar that had a switch (sliding contact) on it as well, but that might have been O gauge.
Mike,
I have no problem wiring the lights, I just wondered how that light track worked. There must have been some sort of arrangement on the light that contacted that 'track' when assembled.
Old 05-21-2019, 06:22 PM   #16
GNfan
Engineer
GNfan's Avatar
Scales Modeled: N
Ummm . . . what is that supposed to be a model of? Maybe a Milwaukee Road EP-2 "bipolar"? I noticed the word "Olympian" on that parts sheet - the EP-2's hauled the "Hiawatha Olympian" from Othello to Tacoma.
Chief Operating Officer of the Plywood Prairie Railroad.
Married to the Chief Financial Officer.
GNfan is offline   Reply With Quote
Old 05-22-2019, 07:04 PM   #17
tjcruiser
tjcruiser's Avatar
Scales Modeled: Prewar Lionel O ... and some dusty HO
Images: 64
Bob, she looks GREAT all decked out in new paint and polished trim. Nice work!!!
tjcruiser is offline   Reply With Quote
Old 05-22-2019, 09:09 PM   #18
Big Ed
Big Ed's Avatar
Scales Modeled: O right now. HO packed/ small N scale table, G scale for under the Christmas tree, & 1 S locomotive
Images: 1
Thumbs up
Looking good , if it was mine I would have did the roof the with same green.
Did that thought cross your mind?
Now, you have to get at least a loop of track to see it run.
Never Enough Room,Time or Money for all the Trains!
I like ALL SCALES/GAUGE'S, I don't discriminate.
Central Railroad of New Jersey
Big Ed is offline   Reply With Quote
Old 05-23-2019, 08:00 PM   #19
rkenney
Dispatcher
rkenney's Avatar
Yea the thought did cross my mind, and then I thought maybe just a green roof edge. All of Grandpas' color schemes were predominately green. I think its fine the way it is.
That's on the list!
Old 05-23-2019, 08:06 PM   #20
Big Ed
Big Ed's Avatar
Images: 1
I thought that too, if not the whole top just the edge as it would match the bottom green.
Does the top just slide off of the cab?
