The birth of a new “empire” - Model Train Forum - the complete model train resource
Go Back   Model Train Forum - the complete model train resource > Model Train Workshop > My Layout
My Layout Showcase your layout here - pictures, projects, progress, whatever!
Old 06-05-2019, 11:43 PM   #1
Andreash
Conductor
Andreash's Avatar
Scales Modeled: HO
Thought I would have some fun and build a 2’ by 2’ HO scale railway. It requires 2 pieces of flex track to complete the circle. The track that will be the trestle sits on the same piece of plywood, I cut the plywood around the trestle, and used a belt sander to thin that section of plywood. A sharpie is used to mask the wood. The bridge will use the ties from the flex track, as I want the bridge to look delicate.
Tomorrow I will solder some power to the track, and fabricate a turnout. The turnout will be non-operational. I’ll then spray bomb the track....I’ll update as I move forward..cheers
Andreash is offline   Reply With Quote
Old 06-06-2019, 12:31 AM   #2
Chaostrain
Conductor
Scales Modeled: N, HO, On30
That looks like a fun little layout. I'll be looking forward to seeing it develop.
Chaostrain is offline   Reply With Quote
Old 06-06-2019, 05:53 PM   #3
Andreash
Conductor
Andreash's Avatar
Scales Modeled: HO
Finished the track work, and spray bombed it. I’ll work on finishing the “bench work” tomorrow. The track work will be embedded into the ground (only the rails will be visible, and some ties.
Old 06-06-2019, 05:55 PM   #4
Big Ed
Big Ed's Avatar
Scales Modeled: O right now. HO packed/ small N scale table, G scale for under the Christmas tree, & 1 S locomotive
Images: 1
Wipe Sweat From Brow
Is that your pet sitting on the wood?
Never Enough Room,Time or Money for all the Trains!
I like ALL SCALES/GAUGE'S, I don't discriminate.
Central Railroad of New Jersey
Big Ed is offline   Reply With Quote
Old 06-07-2019, 03:02 PM   #5
Andreash
Conductor
Andreash's Avatar
Scales Modeled: HO
Finished the box around the track, and am starting the foam landscape. Should have the form done by Sunday. My eight legged assistant has left me for greener pastures..😃
File Type: jpg 8E72700D-8EB5-4339-AAEF-FDAA95AA12A1_1559934049832.jpg (96.5 KB, 2 views)
Old 06-11-2019, 10:28 AM   #6
Andreash
Conductor
Andreash's Avatar
Scales Modeled: HO
The styrofoam has been shaped, and I will paint in the next day. The trestle will be prepared, bridge abutments and scenery should start on the weekend..cheers
Old 06-11-2019, 01:31 PM   #7
Panther
Engineer
Could you post a photo of the complete setup, I'm having trouble figuring where the track is going. Is it two level ?
Dan
Panther is offline   Reply With Quote
Old 06-11-2019, 01:46 PM   #8
Andreash
Conductor
Andreash's Avatar
Scales Modeled: HO
The black spray paint probably doesn’t help, the grey ballast and sand will help after its applied. It is single level...I’m sure once the landforms are painted beige that will make the layout look like a layout The trestle is test fitted for now. I picked up a sandwich bag of trestle bents for $5....some work on a bench sander, and they speed up the process....I’ll add more to the trestle after its installed...
Old 06-13-2019, 12:50 AM   #9
Andreash
Conductor
Andreash's Avatar
Scales Modeled: HO
Painted the base coat and the trestle. I’ll start ballast and scenery on the weekend..cheers
Old 06-13-2019, 08:45 AM   #10
Gramps
Dispatcher
Scales Modeled: HO then G back to HO
Very interesting thread. I'm thinking that the siding is not an actual working turnout. Thanks for posting.
Gramps is offline   Reply With Quote
