Cool I will sticky this thread, so others may take a look. Can't say that this thread will ever get buried, Z does not seem to be a real popular scale here
Maybe I'll get some Z and contribute a few threads on my own. Always thought it would be good for furniture layouts, ie in a coffee table..
It is quiet here so I thought I would fix the engine.
I may have goofed up on the engine, the armature is actually fixed on the base. It showed on the german diagram but i didn't understand it until I read the Z scale org site. The gear will have to be pulled off the shaft. I will just wait for the parts and see.
Walther's came through today.
Parts are in and I will have to remove the worm gear to installl the new 5 pole armature.Moan . One plan is to push the armature shaft out. With a yardsale mic. I measured about 40/ 1000th Guess what? a paper clip is slightly less. I have the chassis structure on the other side if I pull. Chassis obstructs the access to the lower armature. Not good.
So the engine is stripped found some corrosion on one axle. The old motor is dead. It didn't work without a load, (axles removed). The worm gear is sharp.
I did take some Pic,s, but no time today. I used tweezers and my smalllest precision screwdriver for disassembly. Copper contacts could use a cleaning.
You should of seen the size of the shipping box.
it's been a long time since anyone posted on the Z scale section of this forum, so I thought I would :laugh:
I wonder if this scale isn't popular in Canada and the US because you may not have the space issues us Europeans have?
In the UK, cellars (or basements) aren't common in more modern houses which normally leaves a spare bedroom (usually the smallest in the house - my train room is about 6' 6" wide) or the garage, which are generally too small to get anything bigger than a Mini in! Also, garages are unheated, not secure and we can't get gun licences very easily :laugh::laugh:
Well, as long as you stuck with 1:160 say for all your stuff, everything would be to scale. I agree if you mixed sizes then things wouldn't look right. O-scale has some of the same issues, there is "scale" and "semi-scale".
Now where in the world would you go to look that up?
Z scale is very interesting to me. I don't have any of it because it wasn't there when I started with trains and HO was what I could afford. Just because it's tiny doesn't mean it costs less. Can you imagine having the job of assembling those little engines and cars? It would be a short trip to Chatahootchee for me. I'd like to have some z stuff though sometime. Pete
In truth, most of the time the smaller stuff with similar capabilities is more expensive. Don't know why the O-scale stuff is so much more expensive than HO or N, that makes little sense.
Actually, the stuff from Micro Trains, and more recently, the injection-molded stuff from AZL is not expensive, $130 for a geep... decoders are pretty cheap too if you run DCC.
Regards, Greg
update: just realized that I helped further derail the original intent of this thread.
The swmbo person is hard to deal with. We live in a four bedroom house, just the two of us moldy oldies, and dammed if i can have a room for an N scale layout. Have considered Z scale myself. Z on a door might be interesting. First, I want to see someone's z scale stuff in operation however.
No guts, no glory. I'm into N, but would change to Z for space reason if I could affort the steam locos. Just think how much you could get on a T-TRAK module. I'd be in hog heaven. I'm 63, retired, and big hands and fingers, but think I could do it. I was looking at the Z scale steamers, and $600 plus is out of my budget, like way out. So N it is.
Greetings to all!
Ive had all gauges, and even Z once. Downsizing has placed me back on Z scale and I am happy to pursue it. I just wear my glasses more often! Anyone tried the Cortina layout from Noch, and has anyone added the ad ons to it? Happy Holidays!
I've never cared much for HO but the Z is so tiny it's cute. Obviously the emphasis is not JUST on the trains but the entire layout as a whole. I'll give this some thought.
That's a video on my Facebook page, but I can't copy it over here and make it work.
Anyway, that's a Marklin Z-scale starter kit with different cars and a landscape ordered from Noch in Germany. I ordered all the stuff from an outfit in Canada called Eurorail Hobbies and they order stuff from Germany.
I found an end table with a glass top locally cheap, and installed the train in it. This way, I could get a table-top train without tearing up my coffee table.
The glass keeps the cats out!
In the UK, basements (or storm cellars) aren't normal in additional cutting edge houses which regularly leaves an extra room (typically the littlest in the house - my train room is around 6' 6" wide) or the carport, which are for the most part excessively little to get anything greater than a Small scale in! Likewise, carports are unheated, not secure and we can't get firearm licenses without any problem :laugh::laugh:
Related Threads
Model Train Forum
883.8K posts
32.2K members
Since 2006
