DCC and turnouts - Page 2 - Model Train Forum - the complete model train resource
Go Back   Model Train Forum - the complete model train resource > Model Train Workshop > Beginner Q & A
Beginner Q & A If you're new to model trains, stop in here!
Old 05-24-2016, 08:01 PM   #11
traction fan
Station Master
traction fan's Avatar
Scales Modeled: N
Atlas vs Peco
Originally Posted by paulrail View Post
HI, guys. I have a question for all of you who suggested Peco over Atlas. While I'm sure you're right about the overall quality, can anyone explain why locos run over these turnouts better than Atlas?
I am asking because my Atlas turnout has inexplicably worked so much better today but still having more stuttering and stalling than I want (I don't want any). I only have one set of feeders. It's a very small layout at present but would another set of feeders help... or do I just need a different turnout, and if so, why?
Thanks guys
paulrail;
The Peco turnouts have several advantages.
1) A spring that holds the points against the stock rail.
2) A notch in each stock rail that allows the point rail to fit into the stock rail. The combination of items #1 & 2 practically
eliminates "picking the points", a common derailment issue where some wheels take the straight route and other wheels try to take the diverging route.
3) Fairly forgiving dimensions for the guard rails. A strictly accurate turnout works well with accurately gauged wheels, ONLY! Any wheel set that is out of gauge will likely derail.
Peco's system includes some slack. They will accept slightly out of gauge wheels and not derail them.
4) Rail joiners instead of rivets as point hinges. The rail joiners help keep the point rails lined up, unlike the open air gap between Atlas's moving points and their adjacent rails.
5) unlike the Atlas "Snap Track", turnout; Pecos don't attempt to include the geometry of a tight 18" radius curve in their design. Pecos are laid out closer to full size turnouts. They have, essentially, Two straight routes set at an angle. They don't substitute directly for a "Snap Track" turnout because they don' have a curved route. This means Peco is not trying to force wheels into an un-eased, tight curve, across an angled, open, gap in the rails.
6) Everything is built strong in a Peco turnout. Good materials assembled properly.
This may sound like I'm condemning Atlas and exalting Peco. Well, I started with Atlas, brass rail, "Snap Track", just like nearly every model railroader. Then I switched to N scale, and tried Peco. They worked better; and I liked them. Later, I switched to code 55 rail. Back then, there were no code 55,
N scale turnouts available commercially. I started scratch building my own turnouts; and have been ever since. For this reason, I have no axe to grind with Atlas, and I don't get any kickback from Peco. I haven't used either brand for years.
Most of the problems with Atlas can be remedied, and many folks use, and like them. In my opinion, and that of many others; Peco is just more reliable. Trains seldom derail on Peco turnouts.
Regards;
Traction Fan
To Puget sound, Electrified!
traction fan is online now   Reply With Quote
Old 05-24-2016, 08:20 PM   #12
paulrail
Gang Labourer
Scales Modeled: HO
Awesome info, Traction Fan. I love learning more and more about everything I can.
However, my problem is one of a switcher stalling or sputtering over the insufrogs of an Atlas turnout. I am being told that Peco will solve that problem and I'm not arguing... I would just like to understand why that is.
You made some excellent points, but they explain more about why rolling stock doesn't derail and don't seem to explain why locos run more reliably over them.
I will probably just buy a Peco and see what happens because I see on youtube (and other places) that experienced modelers use them...but I would like to know why
Thanks, everybody
paulrail is offline   Reply With Quote
Old 05-24-2016, 08:27 PM   #13
fcwilt
Dispatcher
Scales Modeled: HO
Buy two Peco Code 83 Streamline #5 turnouts.
One ElectroFrog.
One InsulFrog.
Once you have them in hand it will be easier to point out why they work better when you can compare them side by side with an Atlas.
You can also test your locos on the InsulFrog turnout. If it works without issue then you may want to use them as you don't have to bother with powering the frog.
Just FYI, powering the frog on an ElectroFrog turnout is NOT hard just a little more work
Frederick
fcwilt is offline   Reply With Quote
Old 05-24-2016, 08:45 PM   #14
paulrail
Gang Labourer
Scales Modeled: HO
Thanks, Frederick. I have a simple oval of track at this point and am just trying to add a dead end spur. Even my Atlas Insufrog is working pretty well (but not as well as I would like)
I think I will buy a Peco Insufrog first and see how it works. If I can't see the reason for the improvement maybe I'll ask you again when I have the Peco and Atlas to compare
Thanks (wish me luck)
Paul
Old 05-24-2016, 09:41 PM   #15
fcwilt
Dispatcher
Scales Modeled: HO
Just FYI ElectroFrog and InsulFrog are Peco terms.
While the Atlas is (as far as I know) an insulated frog it is not, strictly speaking, an InsulFrog.
Old 05-25-2016, 07:11 AM   #16
cid
Brakeman
Scales Modeled: HO, N
USA
Hi Paul, if the Atlas frog is a little high, it can lift the wheels off the track. They can be filed down to be flush with the rails if necessary. Good luck!
cid is offline   Reply With Quote
Old 05-25-2016, 07:16 PM   #17
paulrail
Gang Labourer
Scales Modeled: HO
Interesting, Cid. I never considered that.
For some reason my loco went through several times at slow and fast speeds but after a while the problems of stalling and sputtering started again. Could this still be frog too high. My frog is plastic...can I still file it down if necessary?
Thanks for the input.
Old 05-26-2016, 12:10 AM   #18
cid
Brakeman
USA
Sure, Paul, I'm not saying that has to be your problem, but I've had to file down a couple of Atlas Customline metal frogs to prevent short locos from stalling like that. You can lay a straightedge or small rule across the frog and rails to check if the frog is high.
Old 05-26-2016, 10:39 AM   #19
DonR
Train Master
If your switcher has only 4 wheel power pickup
you could have problems on any turnout with
plastic frogs. Any loco with 8 (or more) wheel
pickup should have no difficulty at all with them.
If your loco has 8 or more power pickup wheels
and is pausing or stalling on a plastic frog you
may want to check that the wipers and wires
to the motor are working.
If your switcher is 4 wheel pickup the Peco
Electrofrog would solve the problem.
An important point; Peco turnouts use a
different geometry and dimensions than
Atlas and are not a direct replacement. You
may have to realign your track to accomodate
the Pecos.
Old 05-26-2016, 06:17 PM   #20
paulrail
Gang Labourer
Scales Modeled: HO
Thanks, Don. I will get to the bottom this eventually!
