I recently purchased a Rivarossi 4-8-4 FEF from a forum member with the complete understanding that it had a bad decoder install and did not run. What I am wondering from the board is if it can be converted back to DC?
If it has a "wired" decoder,simply cut it off and connect red wire to orange and grey to black.That will energize the motor.If you want to have the light working...then there's a little more to it.Since the original board is gone,you'll need some more help to have them work.You'll need to say if a LED has been installed or if it still has a bulb and diodes and/or resistors will be needed to have them working right.
What about simply replacing the decoder?It is also possible that the actual decoder has its programming messed up.
There are wires between, with a connector. I haven't had time to try and get into the tender yet. I will try to find time to take a couple of pictures if that would help.
Alright. I tore into the tender today and all that I can see inside is what looks like a speaker. There appears to be a capacitor in the cab area. Any ideas or suggestions on getting the shell off?
I haven't done one of these,however the shell is likely bolted on.It probably has one small screw in the smoke stack in front and one or two screws under the cab in the rear.The front screw may be under the front frame too however.
What you just said worries me a bit...seems like a sound decoder was installed then removed.I don't see why there would be a speaker in the tender and the decoder in the loco...all should be in the tender.It would be a good help if you could post picture(s) with shell removed.
I was home with a sick kid today, so my time was limited. I contacted the seller and learned it has a digitrax sound decoder. Once I peel into the shell I will take some photos. Just might take a day or two.
Alright. I finally have time to work on this again. I have opened up the locomotive and it was a digitrax sdh164 chip. I decided to go with brakemanjakes suggestion and I went black wire to gray wire and orange to red. Still a no go.
I dug out my multi-meter and put it on powered rails. There is power to the rivets that the wires are soldered to, but not to the ends of the wires that are soldered to them... So I am going to test my soldering skills and see if it was simply a bad solder job on the power feeders. Wish me luck.
I bought a Rivarossi PM Berkshire off of ebay. It had a Digitrax Z scale decoder in the loco shell. This was my first foray in to upgrading to sound, so I bought a Digitrax sound and motion decoder. Changed it all to tender mounting and used the Soundtraxx 9 pin tender to loco plug set to get motor power, track power pick up and light poer to the loco. Modified the tender to hold the chip and the speaker, and also has additional power pick up. Worked really well! So then I upgraded to the Tsunami Heavy Steam. Y ear later, still working very well.
Related Threads
Model Train Forum
883.8K posts
32.2K members
Since 2006
