I have a Lionel 51 Navy Yard Vulcan that needs some help. It runs very choppy, for a lack of a better term. It's very sporadic in its speed and does not run smooth at all. Any help or advice would be very appreciated!
Thanks, Jim
The most obvious answer would be needing a good overhaul of the motor. You would need to clean and lubricate the motor, replace the brushes, and lubricate the axles. I don’t know your experience level or your capabilities to do that? Do you have a Service Manual, necessary tools, etc.. We can guide you through the process, or you can take it to a Lionel Service Station, (hobby shop).
Likely a dirty motor commutator face and either very worn or very dirty brushes. New brushes made a world of a difference for my Postwar F3 diesel locomotive after it had been exhibiting similar issues on its first test run.
I have one of those. Actually I just have the frame and motor. It runs pretty well.
One thing I have had problems with on the gang car (basically the same thing). Was the collector spring no longer holding one pickup roller down against the center rail. This causes some power lapses, if the power drops off completely it will cycle the E-unit and reverse directions. clean your pickup rollers first and make sure they have good contact (spring part # 41-24 is in place).
Be careful not to iover-tighten the body screws during re-assembly. Cracked, broken mounting holes is one of the things you see damaged most often on these locomotives bodies.
Included in an overhaul would be a good wheel cleaning (all of them). They are the common connection to power. My favorite method: hook the transformer wires to the engine and run it upside down. Then use the CRC on those green kitchen pads - the ones about 3/8" thick (pack of six 3" by 6" at my dollar store). Soak the pad with some CRC and hold it against each wheel until no more black comes off.
The pad are good for cleaning track rails as well. The CRC tends to get pricey for that job so I use 90% isopropyl alcohol to soak the pads. I use alcohol on the wheels as well.
Thanks guys! Would a weak spring on the pickup rollers cause sparks at the wheels? Because they are sparking!
I am old but new to this, so forgive me!!
Thanks again!
fotojocbi, Chances are that it would cause sparking, if it is weak enough to let it bounce, while running. You could also have dirt/carbon build up on the rollers that will do the same. I would just buy a new replacement. As far as maintenance, I would replace the motor Brushes, and clean the copper segments of the armature, before putting new brushes in. The collector assembly (rollers), is part #41-18; brushes are #622-121.
Are you capable of fixing it yourself? It isn’t hard, but takes some patience. Also, do you have a Lionel Service Manual, to reference part numbers, and see diagrams of your particular item? We can talk you through this, and give you more info for parts dealers. If you don’t have a Service Manual, you can see one on-line, at Olsen Toy Train Parts. (Olsentoy.com).
Thanks for all of the advice. Brushes looked bad so I ordered some of the 622-121 brushes, along with the springs. Cleaned the armature and will clean the wheels as well as the rollers. Will give update once the brushes come in.
Thanks, Jim C.
It would be a good idea to get Contact Cleaner, (CRC type), and spray the E unit finger area, along with the inside wheel/axle area. Use oil on the inside of the wheels, where they meet the axles, so that the oil wicks into the axle bushings. When you get& replace the brushes, everything should be fine. Good luck.
Brushes came in today and I installed them and she runs as smooth as silk!
Thanks for all your help!!
Jim
Related Threads
Model Train Forum
883.8K posts
32.2K members
Since 2006
