SCARM - Simple Computer Aided Railway Modeller - Page 3 - Model Train Forum - the complete model train resource
Go Back   Model Train Forum - the complete model train resource > Market Place > Product Promotion
Product Promotion If you are a vendor with a nifty product please post here!
Old 02-22-2011, 04:56 PM   #21
gunrunnerjohn
gunrunnerjohn's Avatar
Images: 3
Perhaps you could attach the two files here to the message?
Old 02-22-2011, 05:08 PM   #22
Mixy
Brakeman
OK, here is the lib attached, but for the program package, the forum says that it is over maximum file size limit and cannot be attached. See my PM to you.
Mixy
File Type: zip Lionel-O-tmp.zip (705 Bytes, 3 views)
Mixy is offline   Reply With Quote
Old 02-22-2011, 05:45 PM   #23
gunrunnerjohn
Images: 3
Here is the other type of O31 switch I spoke of. This one is an interesting switch, it's a compact version that can be used in switch yards, or expanded with the included add-on sections to the dimensions of a standard O31 switch like the 022. Let me know if these pictures are sufficient.
I got the ruler backwards, but you can see the switch is 5.5" wide here, including the lantern section.
Note the straight section is just over 8" long without the extension, with it, it's the standard 10" length of an O31 straight track.
This curve extension makes the curve the standard 11" length of an O31 curve.
Here's a measurement straight across the curve without the extension.
Here's the switch with both extensions installed. This makes the track part the same size as the 022 switch, obviously the lantern section is still different.
Here is one of the interesting parts about this switch, and one that I plan on probably using in my switch yard. you can cut off the lantern section totally, all you lose is the indication of switch position. Since you also get that remotely from the control switch, that's not much of a loss. Cutting this off and also using the short curve section allows you to have closely spaced tracks for a switch yard.
Old 02-22-2011, 05:47 PM   #24
NIMT
Yard Master
NIMT's Avatar
Images: 35
Mixy,
I've been working with it for a few min and I like it, Works really good.
I will work with it more tonight!
http://www.northidahomodeltrains.com
NIMT is offline   Reply With Quote
Old 02-22-2011, 05:51 PM   #25
novice
Engineer
novice's Avatar
Scales Modeled: O & HO Kinda
Images: 135
Originally Posted by gunrunnerjohn View Post
Hmm... Trying to go to the site http://www.scarm.info/index_en.html and it's dead. The ZIP download times out as well.
Just use this link to get the site:
novice is offline   Reply With Quote
Old 02-22-2011, 05:54 PM   #26
gunrunnerjohn
Images: 3
You're missing the point, there seems to be a routing issue between my ISP and his site.
I tried that. Now the old link is working, Verizon must have gotten off the dime.
Old 02-22-2011, 05:58 PM   #27
Mixy
Brakeman
Thank you, guys
@gunrunnerjohn: The pics are OK, but I will see them tomorrow, because here is 1 hour past midnight and I am going to sleep, again
Please tell me some link from where I can see the names and part numbers of Lionel together, because in Lionel’s catalogue that I have, there are only part numbers of the tracks and I am unable to associate them with names that you are talking about.
Mixy
Old 02-22-2011, 06:15 PM   #28
gunrunnerjohn
Images: 3
Lionel's "official" part numbers for these switches.
602-3010-000 "O" Gauge Switch (Left Hand)
602-3011-000 "O" Gauge Switch (Right Hand)
The "generic" name for them is 3010 (left) and 3011 (right).
BTW, how do you make a custom length of track?
Old 02-22-2011, 06:26 PM   #29
NIMT
Yard Master
NIMT's Avatar
Images: 35
gunrunnerjohn,
Is there a "flex" track for O? or O27?
That's how I make custom lengths in HO.
Old 02-22-2011, 06:31 PM   #30
novice
Engineer
novice's Avatar
Images: 135
NM - revisted site and it worked
Tags
design , layout , model , railroad , software
