SCARM - Simple Computer Aided Railway Modeller - Page 2 - Model Train Forum - the complete model train resource
Go Back   Model Train Forum - the complete model train resource > Market Place > Product Promotion
Product Promotion If you are a vendor with a nifty product please post here!
Old 02-21-2011, 04:58 PM   #11
Mixy
Brakeman
Thank you, gunrunnerjohn
Pictures are clear and detailed. Now is midnight here so I am going to sleep, but tomorrow I will try to map the pics to track library file. Hope that Lionel O lib will be ready and tested till end of the week
Mixy,
from Bulgaria
Mixy is offline   Reply With Quote
Old 02-21-2011, 05:04 PM   #12
gunrunnerjohn
gunrunnerjohn's Avatar
Images: 3
Great, glad I could help. Next, I'll post the other type of standard O gauge switch that is different.
Old 02-22-2011, 03:27 PM   #13
Mixy
Brakeman
OK, here is preliminary Lionel-O library file: http://www.scarm.info/temp/Lionel-O-tmp.zip. Download and extract it from archive, then copy .lib file into LIB folder of SCARM. Start the program and select Lionel-O from the libraries dropdown menu. At the moment, all tracks are labeled with their part numbers and only 14062 and 14063 turnouts have attachable accessories enabled. Select one of these turnouts with buttons from the selection panel to place on the plot – a dialog with possible accessories will appear. Select the switching motor (left or right) and press OK. This is the way how track accessories are realized in SCARM. Unfortunately, the Lionel catalog has no dimensions of these things at all, so I will ask you to tell me other possible switching motors dimensions and offsets in order to be able to put them in the library file, as marked on the picture. Offsets are horizontal and vertical dimensions from start of center rail to nearest corner of the motor. Try the lib and tell me – am I close or not?
Mixy
Old 02-22-2011, 04:09 PM   #14
gunrunnerjohn
Images: 3
Hmm... Trying to go to the site http://www.scarm.info/index_en.html and it's dead. The ZIP download times out as well.
Old 02-22-2011, 04:25 PM   #15
NIMT
Yard Master
NIMT's Avatar
Images: 35
Mixy,
I would have to say that most of us in the U.S. are oblivious of the metric system is there any easy way to convert the track to SAE (Inches and feet) measurements?
http://www.northidahomodeltrains.com
NIMT is offline   Reply With Quote
Old 02-22-2011, 04:26 PM   #16
gunrunnerjohn
Images: 3
Good point Sean. I can't get to the site right now, so I haven't actually seen the package yet.
Old 02-22-2011, 04:39 PM   #17
Mixy
Brakeman
Hi guys,
I checked the SCARM web site 2 minutes ago and it is up and working well. May be it is a temporary problem or something in the route. Check it again and tell me if the problem persists.
@NIMT.COM: Open "Tools" > "Settings" > "Measurement units" tab and select inches to be default dimension unit
Mixy
Old 02-22-2011, 04:44 PM   #18
Mixy
Brakeman
See also FAQ section in the site or in build-in documentation (F1) – it takes 10 minutes of reading, but explains a lot for SCARM features, tips and tricks
Mixy
Old 02-22-2011, 04:47 PM   #19
NIMT
Yard Master
NIMT's Avatar
Images: 35
Mixy,
Excellent, thank you
From a business point of view you might want to add in an US flag, English, with the dimensions defaulted to inches.
Oh and atlas code 100 track too! A lot of us still use it.
Old 02-22-2011, 04:54 PM   #20
gunrunnerjohn
Images: 3
Still no joy for some reason. I can do a tracert to it, but when I ping it, I get timeouts. The odd thing is I got a couple of responses, then nothing.
I did get to it with a proxy server, but I can't download using that proxy. I'll wait to see if this gets sorted out.
Tags
design , layout , model , railroad , software
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
