1 - 6 of 6 Posts
hi guys i'm building a small 4x4 layout just for under the christmas tree... i found some track plans, one is an 18" radius "main line" with a 15" radius "spur line" the other is 18" on both... most of my engines are older but i'm wondering if i could get an old 0-6-0 mdc switcher to run on the 15" radius without much headache?? i really like the one plan with the cross over and the 15" radius loop but i would also like to keep the trains on the track...i've been collecting since i was a kid but this will be my first layout build and practice for my big layout thanks for any help guys
Welcome to the forum.:thumbsup:
Your 0-6-0 should handle it just fine. Would you believe my 4 axle Athearns handle 14" with nary a hitch.
The upper loop on my Christmas layout is done in 14" radius...
thanks for the quick reply i plan on getting track today and start building so it will be up and running for the holidays! my father had a small layout when i was very young and had an 18" main line and i believe it was 15" over under figure 8 in the center that gave alot of problems but i think it was a combination of grade and tight radius? it was on a 3x6 if i remember correctly... i was checking out your layout in the gallery very nice! wish i could get that much track in a small place but its a family affair and i have to leave room for the girls to put their town... guess i could sneek in some sidings and switches in! haha. at the very leaste it will be good paractice for my big layout someday... thank you again for the quick reply
thanks for the quick reply...my father had a small layout when i was very young and had an 18" main line and i believe it was 15" over under figure 8 in the center that gave alot of problems but i think it was a combination of grade and tight radius? ... i was checking out your layout in the gallery very nice!
You're welcome. Yes, it no doubt was the grade/curve combo as there needs to be about 2 1/2" minimum clearance between tracks. If he kept it tight, there would have been no real way to make a smooth transition. Thanks for the kind words regarding my layout. There actually is quite a bit of space for a town in there, including the tree.
shaygetz, you are the man. If I ever have a problem I will probably pm you about it. I am looking forward to meeting you some day, If not here then singing in halleluia square.
Les.
Awwww, shucks...:eek::D
Here, there or in the air:thumbsup:...wish I coulda met you when I lived in Georgetown, DE,---Townsend wasn't that far away.
1 - 6 of 6 Posts
