1 - 8 of 8 Posts
I have the makings of what would have been a Lionel box set (though I acquired each of them separately.)
A 1947 version of the Lionel 221 - with the nickle rimmed drivers - the tender is a 221W.
What I believe is a 1947 version of Post War Lionel Pullman cars - 2430(2) and 2431(1). They are of the blue and silver variety.
At least one of the cars is in kinda rough shape on one side - lots of what I hope is just surface rust, and two cars are missing the couplers on one end.
I ended up paying 60 for the engine and tender - which aside from some sparking on the tender and a wheezing whistle - the engine runs very smoothly backwards and forwards.
I will take apart the shell and do a de-rusting on the few areas that need it and a restoration and a repaint. (Not looking to sell it, so I want to make it look new again. )
I might replace the original light bulb with LEDs and wire a harness between the engine and tender for a white prototypical backup light on the tender as well - Don't know yet.
I am also entertaining the idea of adding an AC commander to the tender - I know that this has been discussed before here and I dont know if there was ever found a way to isolate the tinplate shell - so if anyone has any ideas on that front please chime in!
On to the cars - considering their shape and the condition of the one car - I talked the seller down to $65 shipped for all three of them - that's 20 bucks a car - the value that I found when I was researching was $27/car in fair/good shape and $65/car in mint condition - so I think that both of us got a pretty fair shake on that front.
I can use the Easy-Off trick on these cars without worrying about "melting" them correct? This will be a first foray into a restoration like this - I found a pretty good YouTube series on restoring tinplate cars that I will follow religiously (along with any tips and tricks from you guys) - but he used a thinner bath to get the paint off and electrolysis to get off the rust - I don't have the setup for that in my apartment and I def don't need to have a hydrogen gas factory on my small back porch!
Thanks for looking guys - and as any thread is useless without pictures I will post pics and document this all when I get home from work!
Do y'all think that Jeff at Train Tender would have the parts for the coupler - or would I be better off trying to find an original or repro entire truck assembly?
I said at the end that I'm at work and will post pictures when I got home.......
Sent from my iPhone5 using mind control!
Jeff will definitely have parts so will hennings.
Don't worry much about the hydrogen. I use electrolysis routinely for 1000 lb. machinery castigs, without issue, in my detached garage. You're talking about a micro-scale bath, here.
What are you using for anode, power source, and connector leads?
Thanks guys! GF took us out to see Mockingjay tonight - so pics coming ASAP!!
SNK,
Sounds like a fun project. I did a 221 restoration in this thread ... you may find it useful ...
http://www.modeltrainforum.com/showthread.php?t=3483
(The thread starts with some under the hood pics of a 221 that I purchases as is, and then goes on to a full restoration of another 221 I picked up.)
You may also find this thread on my 610 / 612 passenger cars useful. EasyOff strip, Dremel stainless wire brush buff/polish, prime, paint ...
http://www.modeltrainforum.com/showthread.php?t=8795
They're not exactly your passenger cars, but the process is similar.
Good luck!
Edit -- oh, sorry, SJM ... just seeing now you posted one of my thread above. Thanks for the thumbs-up! ;)
1 - 8 of 8 Posts
