The front of my 2025 is resting on the track and keeping the unit from proper operation. The front wheels are not supporting the units weight. If there is a way to correct this at home please share. Thanks in advance
What is a 2025?
So if by this you mean the number painted on the side (or a number plate) this isn't the way to describe the loco. That's only the identifying number assigned to the loco by the owning railroad. Most of the ones on our models are fictitious, meaning that there wasn't a real loco of that type with that number.The number on the steam engine. I apologize if my nomenclature is incorrect.
Is that true? I thought the main drivers were enough support to keep a properly assembled Lionel 2025, and keep it level.The 2025 is a "Prairie" 2-6-2 wheel arrangement loco, made from 1949-1952. The problem you are describing, is most likely a weak spring in the pilot truck assembly, under the steam chest. The part number for a replacement is 675-19 from WWW.TTENDER.COM, (Jeff Kane) for $6.00. A weak spring on the front truck assembly, will cause the front of the loco, to drop, and drag the rails. ...
http://pictures.olsenstoy.com/cd/locos/loc675p2.pdf
For O scale that does ID the locomotive.So if by this you mean the number painted on the side (or a number plate) this isn't the way to describe the loco. That's only the identifying number assigned to the loco by the owning railroad. Most of the ones on our models are fictitious, meaning that there wasn't a real loco of that type with that number.
I appreciate the help. I have corrected the problem. I had the engine proper gone through and all I was looking for was some information to adjust the front wheels because the front of the train engine or whatever was dragging on the track. My solution was simple, bend it down which lifted the front up off the track enough and the thing runs great.
So I gather from the other replies, but since there was no indication in the original question that it was O scale, I was flying blind and spitballing.For O scale that does ID the locomotive.
Anyone into O knows right away what the 2025 is.![]()
So, what did you bend down? As pointed out in an earlier post the front (pilot) truck supports absolutely nothing on a 2025. It is there for show only, the loco should run just fine without it.My solution was simple, bend it down which lifted the front up off the track enough and the thing runs great.
