1 - 4 of 4 Posts
Hey, Guys
We have received the 30-20521-1 MP15DC Diesel Engine w/Proto-Sound 3.0 - Union Railroad (Spirit of ‘76) Patrick’s Trains . These engines are almost sold out. We received half the shipment and the rest are due March 10th.
Thanks
Pat
WWW.PATSTRAINS.COM
PATRICK'S TRAINS
142 29TH STREET
WHEELING WV 26003
304-232-0714
http://www.patstrains.com/View_Details/?ID=48855&View_Details=View+Details
PRE-ORDER, ONLY AT PATRICK'S TRAINS SPECIAL RUN 50 PIECES ONLY. OTHER HALF OF RUN WILL BE AVAILABLE IN MARCH 2019. Intricately Detailed, Durable ABS Body Die-Cast Truck Sides, Pilots and Fuel Tank Metal Chassis Metal Handrails and Horn Authentic Paint Scheme Metal Wheels, Axles and Gears (2) Remote-Controlled Proto-Couplers Prototypical Rule 17 Lighting Directionally Controlled Constant Voltage LED Headlight (2) Precision Flywheel-Equipped Motors Onboard DCC/DCS Decoder Locomotive Speed Control In Scale MPH Increments 1:48 Scale Proportions Proto-Sound 3.0 With The Digital Command System Featuring: Freight Yard Proto-Effects Unit Measures:13” x 2 1/4” x 4 1/4” Operates On O-31 Curves Diesel DCC Features F0 Head/Tail light F1 Bell F2 Horn F3 Start-up/Shut-down F4 PFA F5 Lights (except head/tail) F6 Master Volume F7 Front Coupler F8 Rear Coupler F9 Forward Signal F10 Reverse Signal F11 Grade Crossing F12 Clickety Clack (On/Off) F13 Idle Sequence 4 F14 Idle Sequence 3 F15 Idle Sequence 2 F16 Idle Sequence 1 F17 Extended Start-up F18 Extended Shut-down F19 Rev Up F20 Rev Down F21 One Shot Doppler F22 Coupler Slack F23 Coupler Close F24 Single Horn Blast F25 Engine Sounds F26 Brake Sounds F27 Cab Chatter F28 Feature Reset This product may not have shipped yet or is completely sold out. Click on the show button to see who might have it on order.
Stock Number:
30-20521-1
Gauge:
O/O-27 Gauge
Manufacturer:
MTH RailKing
Product Type:
Locomotives
Price:
$329.99
Availability:
Pre-order DUE MARCH 10TH
30-77339 Bay Window Caboose - Union Railroad (Patrick’s Trains) 2 NO. 1776, 1976
http://www.patstrains.com/View_Details/?ID=49563&View_Details=View+Details
ONLY AT PATRICK'S TRAINS 100 PIECES MADE WITH 2 ROAD NUMBERS 1776, 1976 Intricately Detailed Durable ABS Body Metal Wheels and Axles Die-Cast 4-Wheel Trucks Operating Die-Cast Metal Couplers Colorful, Attractive Paint Schemes Fast-Angle Wheel Sets Needle-Point Axles Near-Scale Proportions Overhead Interior Lighting Unit Measures:10 1/4 x 2 1/2 x 4 1/4 Operates On O-27 Curves
Stock Number:
30-77339
Gauge:
O/O-27 Gauge
Manufacturer:
MTH RailKing
Product Type:
Freight Cars
Price:
$69.95
Availability:
In Stock
Good Evening Everyone,
A couple weeks back, I picked up my Union Railroad MP15DC Bicentennial engine from Pat. MTH did a nice job on the overall paint scheme. They overlooked a few things however, and being who I am, I couldn't help myself and set about to correct a few things. On the real prototype engine, the exhaust stacks are painted silver(MTH did white), both pilots are painted white(MTH did black), and the walkways along the long hood and the pilot decks are black(MTH did white). Of course, this required disassembly of the engine to do a proper job. That was ok though, as I needed to carefully pry the cab figures away and reverse their positions to be facing out the rear of the cab as the Union Railroad normally operates the lead engines running cab forward. While the shell was off, I also reversed the motor lead wires in their plugs so the MTH running sequence is now N-R-N-F. Also reversed the headlight wires in their plugs to keep them in sync with engine direction. In addition, in order to unscrew the pilots from the trucks for painting, the motors must be unscrewed from the trucks in order to gain enough wiggle room to have access to the screws that mount the pilots to the trucks. I used Krylon spray gloss white, Krylon spray satin black and Testors flat aluminum bottle brushed on by hand. The final details were adding the vertical number 17 on the back of the cab along with the required Coleman cooler on top of the battery box. It took a while, some patience and a little swearing, but I'm happy with the result.
1 - 4 of 4 Posts
