1 - 1 of 1 Posts
Picked up ANOTHER 4-piece boiler 302. This one doesn't run, which is fine with me, and has the wrong tender and shell..While putting power to it, it would run 1/2 revolution and then bind up TIGHT!!. Quartering is off, right?? Well, I pulled the linkage off and the same thing was happening...The next thing you want to check is the smoke gear. I pulled the loco down to it's bare chassis, and the smoke gear was so loose, it was wobbling and causing the armature to bind. One good whack with a brass punch and a small hammer on the smoke gear pin and it was fixed. No more binding.. I noticed another thing with this loco, someone had put on a pair of pul-mor rubber tires on it. The tires are in great shape so I'll pull them off and return it to original. Transport Vehicle Scale model Locomotive Car
Auto part
Auto part Rim Vehicle Wheel
1 - 1 of 1 Posts
