1 - 7 of 7 Posts
I notice that the tender rocks a lot. So i took tender shell off and notice. I can take truck and push it up and down alot so i presume the revits r shot and have to be replace just want your advice before i take it apart. Thanks
Al
A 322 tender should not visibly rock when running. If so the trucks are not firmly mounted. If you redo the mounting be sure to use all the correct parts.
Ok when it sits on track or run it does move especially on curve i can see the revits have alot of play. I know it will have a slight rock. So looks like l will be doig that i have some revits not sure they r for a hudson so i wil just order the revit kit for . thanks
Al
1 - 7 of 7 Posts
