It occurred to me last night that I should be able to create my own jigs for hand-laid turnouts. The plastic won't hold up to a lot of sloppy soldering but it should hold up well enough to get the rails in place and tack down some key points. Even if a jig only gets used a few times, they would be so cheap to print that you could just throw them away.
Looking over Thingiverse, I did find one item which printed the ties to go with a Fasttracks jig, and that seems like a good idea to include. The real trick is being able to write up something that can generate the jigs to whatever size you need. I could lay out something on Tinkercad but that seems like a waste of time. Guess it's time to learn some other CAD modeling program.
