1 - 5 of 5 Posts
I'm using Anyrail to design my new layout. I'm using the #5 Peco turnouts from my first crack at this and I know my 60' cars and SD40-2s run well on them.
Problem is that in the Anyrail track library there is only a Peco #4 wye (code 83). A quick google search suggests no other size exists. Will this equipment be alright on a #4?
Thanks, all
Paul
Paul
Here is a pic of the Peco #4 wye.
http://www.hobbylinc.com/peco-code-...oFdAlMFOOjCAJ70rJHuXW7yFAkkiCzUBoCojgQAvD_BwE
I don't have either your loco or the wye, however, checking
the wye in the attachment, it appears that there is little
curvature in the routes. Even tho
the loco has 6 wheel trucks I would think that
it should negotiate this wye satisfactorily.
If any of our members has experienced this situation
I do hope that they will comment.
· Premium Member
Thanks, all
Paul
Paul, wye turnouts are different; the frog number isn't the amount of diversion from the through route like it is in conventional turnouts. Wye turnouts' frog # is the sum of the diversion BETWEEN the two routes...so it's really like a #8...except two of them back-to-back, sharing the same frog.
BUT...Peco did something a little different with their #4 Wye using a somewhat smaller radius to get a shorter turnout:
Read this thread...it's worth the trouble:
https://model-railroad-hobbyist.com/node/34901
At Fast Tracks, the place where you can learn to make your own turnouts, they have an extensive library of templates...printable ones.
https://www.handlaidtrack.com/tt-ho-y-4
Click on the 'download' icon and when it loads, you'll see, if you imagineer a through route instead of the other diverging route, that a #4 is really half of a #8 on each side.
Thanks for the info and the links! I learned a lot from reading.
Paul
1 - 5 of 5 Posts
