21 - 24 of 24 Posts
Glad you got your RPMs up. Way to go. This shows the difference between a parts changer
and a mechanic. A mechanic fixes things.
I do have an Alco PA diesel with the dual open frame AC motors. Not an AF original locomotive. It is a Lionel/American Flyer locomotive from 1981. Even though it is newer
it still gives me fits. Did I ever tell you I hate open frame AC motors?
Give me a DC can motor any day.
That is indeed a good fix. The brush holders on my engines look completely different. Are they repro's or originals, I have never seen that style. They lend themselves well to the lever arm style fix, which is what you did with the heat shrink.
If the wires going to the brushes are not in the correct position, they will have a negative effect on the brush spring tension. It appears by adding the wedge you increased the spring tension.Also, if the brush plate slots are elongated just a little, that will also have a negative effect.
21 - 24 of 24 Posts
