1 - 14 of 14 Posts
I haven't visited here in quite some time. This is where my layout was: http://youtu.be/D440sfOGoPg
As it turned out the porch was not a great idea. The dirt that blows in, plus the moisture when it rains is too much of a problem. So, my wife has given me the garage to use. I've purchased a winch and the plan is to be able to raise the table to park a car below.
I want to use 72" diameter curves for part of the layout for my LIONEL 752E PREWAR O GAUGE UNION PACIFIC M10000.
I have many operating accessories for moving coal etc. So I will need sidings. I would appreciate layout ideas for a 8 x 14 layout that will run up to four trains.
Thanks,
Gary
Discussion Starter #2
Oh, and I'm wondering about having a central opening in the table. Is it a good idea to have that kind of access?
how big was the porch layout? u had a lot going on there.
i think center access is good idea. u will need it.
There has to be some sort of access to the center
part of a layout that big.
Think reach of your arms. Will you be able to
reach everything on the layout?
If not, maybe you could have a removable section that
comes off from under the table. That way if the
inevitable derailment happens you can have access to it.
layout plan assistance wanted
The current layout looks like the attachment. There are two 8x4 sheets and the smaller end is approx 6x3.
My first layout had an operator pit in the middle with crawl-under access. Never again.
If you do it that way, put in a gate or lift-up section so you can still walk in without having to crawl/stoop.
Hobo for Life
I liked the old layout and mix of stuff. Only problem I see is it will be heavy to hoist! You dont seem to have trouble with buildind layouts. Get the table done and layout some test track. I find in real life some stuff dosent work as well as it does on paper! I like my dogbone on my inside track. I ran a few sideings off of it to accommodate some accessories. they arnt long but I mostly park stuff that works with the accessories, not much switching for me but I can power up coal loaders and such while I run the trains on the other tracks. Just an idea as it seems you like the accessories too! Good luck, and shoot pictures.
Discussion Starter #12
to gunrunnerjohn,
To isolate a track section do you use insulated pins in all three rails? And what does it mean to make sure to keep all the different sections in phase?
thanks,
Gary
1 - 14 of 14 Posts
