I haven't looked at the bridge wiring ... I presume the insulated track's ground connection will raise the bridge. But will the bridge continue to raise to it's fully open position if the ground connection is broken before it finishes? Or is only the manual button able to momentarily trigger and initiate the bridge's full open or close cycle?
The activation button only needs to be pushed for about a second or two. Once it's pushed, the bridge will rise then stop in the raised position until the button is pushed again. And vice versa for going down.
If I take the two wires that go to the activation button and touch one to an outside rail and the other to the insulated rail, then pass a car over the insulated track section, the bridge goes the same scenario.
If the car stays on the insulated section, the bridge will continue to raise, lower, raise, etc, etc.
