1 - 17 of 17 Posts
I now have a 307 that smokes (well). Rummaging through my parts box I found everything I needed to add smoke to a 307. Now all my Steamers have smoke!
One of the front Pul-Mores is in pretty bad condition I'll tackle that next. It's keeping me out of trouble (kinda).
No on the hole. I would have to drill a hole. The E unit in boiler. Best way for me would be to buy a Silver Streak loco with smoke and switch the shells. Silver Streak is a Bullitt
loco also.
I could move e-unit to tender and add a smoke unit.
A smoking Royal Blue would be cool also.
The position of the stack on the plastic Silver Streak shell is not is the same position as the non drilled stack on a Royal Blue shell. So the Royal Blue stack when drilled out will not line up with the smoke tube. It can be done but it is not a straight swap.
I think the best way would be to get a 356 with failed chrome or even a scratched up 354 to paint and decal as a Royal Blue. Easier than switching the shells because the next issue is a Royal Blue tender has no reverse unit so those bodies also need to have a chassis swap.
Discussion Starter · #6 ·
When I was missing a red stack, I used a small aquarium type hose so the smoke went up, not all over. A dab of silicone held it in place and was flexible.
loco also.
I added smoke to my Royal Blue. Also added a can motor with a flywheel and an electronic e unit. Works great. The smoke unit fit fine in the shell, but the hole in the smoke unit itself had to be moved back a bit. Still works great.
I knew you had added smoke to your Royal Blue. I was hoping you would post.
I did not know the smoke stack did not line up. Thanks Tom for bringing that up.
Does not sound like it is that big of a deal though. Thanks for the info guys.
So you moved the smoke tube?
Discussion Starter · #10 ·
A can motor, half speed worm and an electronic reverse unit is the way to do it!
Mopac, the Royal Blue tender shell also needs to be swapped to the Silver Streak tender chassis.
I've been curious about those Can Motors for my Baldwin 355. Because of the cost I haven't pulled the trigger yet. Also I've seen little feedback from those that upgraded. I'm interested in what you think about them after installation.
Yep. Marked the top of the smoke unit through the hole I drilled in the boiler, and put in a new smoke tube while sealing up the old one. Works great.
1 - 17 of 17 Posts
