1 - 9 of 9 Posts
This feels like a silly question. Are there any DCC decoders that are all in one? Sound and DCC function together, or do you need both separate? The reason I ask is that while looking at the wiring on a few different models online, the sound decoder has leads to the motor. I'm not sure why the sound board would connect directly to the motor unless it's a basic DCC decoder as well as sound.
Thanks for that. Kind of what I figured, but most only talk about the sounds and not the speed control etc that the non sounds versions talk so much about.
You have to be careful not to fall for the marketing hype. Of course, the manufacturer of a non-sound decoder is going to hype how well it can dial in motor performance. Sound guys try to compete on sound. Basically, the non-sound decoders haven't changed all that much in the last ten years or so. I'm still buying more or less the same ones I always have. Sound is where everyone's energy is these days (I don't want sound, for the simple reason that it doesn't scale properly).
That's intended for N; the 0001913 might be a better selection. Not a lot of info on the web- apparently they make some decoders for MRC. For $30 you might take a chance...:rolleyes:
?? Says HO. 1913 looks like the same thing but in two pairs with PIN connectors. None of my locos are DCC ready.
1611 is a 1 Amp Decoder. It might be OK for you. I guess I would try it, probably easier.
1913 is a 1.5 Amp Decoder. The speaker is probably a bit larger. Not that familiar with them. I don't think MRC has the best decoder reputation.
Hope some others might chip in with sound decoder experiences... :D :D
1 - 9 of 9 Posts
