1 - 10 of 10 Posts
I have this caboose from a junk lot and decided to have some fun.
The best way would be to cut a piece from another scrap but I didn't have any so I used Bondo to form a crude mold. I cut back over the wall to support the new piece. Glue was on the old shell so a previous repair didn't work.
Then the fitting and epoxy. The scratch coat to cover defects.
I sanded with 400 grit and painted with acrylic by brush, a mixture of red and brown. Now, it sorta looks like a caboose.:)
Discussion Starter · #7 ·
As I mentioned It would look sharper if I used pices from junks instead of making them. It looks fine now but I can always go back and work on it. I am not sue if I can add anything else. I guess this is just a form of kitbashing.
You better slow that train down t-man! Your going to have the yard master after you! :D
Discussion Starter · #9 · (Edited)
SPEED part of the problem is the engine stalls on slow.
The older engines speed up after a few laps. That's what happened.
Thank you for the conscious effort.
It only derailed on the last take and stopped at the switch tower.:rolleyes:
Yeah, the accident report will take forever since no engine was involved.
The roof piece is still off so I sanded some more and used a barnred/brown mixture.
Discussion Starter · #10 · (Edited)
Continued
One good thing is that you can make your own rules and standards. I got tired of the poor casting on the roof. I did more sanding to bring the top flush then I removed the hatch and the center walk plank. I returned to my scrap caboose and cut two more pieces to fix. Pieces are fitted in and I am in the finishing stages. It looks better.
That paint is just an eyeball mix of a brick red and brown acrylic.
Neat Huh!.
1 - 10 of 10 Posts
