This project was talked about early spring. There is an article by Ken Stone on how to do it. As with most projects I start with a diagram. I gather the parts. Then I try to place the info on a breadboard and get it to work. Then lastly, I solder the parts onto a board. It only looks complicated because of the number of parts. A flasher looks simple. Each piece is placed in the right connection and in the right direction.
Update. I also have a Flame Flicker Board I built with the specifics at this thread.
If you read the article, this board will run off a DC power pack. HO guys take note.I plan on using my
12 volt updated power supply.
For a brief parts description I have resistors, capacitors, diodes. a Zenner diode, two transistors and a 14 pin IC chip.
So far I substituted A 2M2 resistor, for 2, 1 million and 1, 200k resistor.
Also I used 2, 33k resistors for a 68k replacement.
I will be using an LED 8000mcd. Considered super bright when the article was written.
Everything started with the chip. 1 to 14 pins counter clockwise. I numbered the four corners. I forgot the numbering my first mistake.
Time to the fix errors.
Since I don't have a prefab board the work up will help me place the pieces for the final assembly.
