Athern HO DCC ready, decoder selection
1.9K views 4 replies 2 participants last post by  J.Albert1949
#1 · (Edited)
Hey guys,
So I’m getting back into the hobby, and I’ve purchased an HO DCC ready Athern SD40-2 in Milwaukee Road colors.
Instructions say 8 or 9 pin decoders work. Which would be a wise choice to purchase? Great little access panel on the top of the locomotive, but very limited on space it seems. I’ve never installed a decoder or programmed anything before, and I’d like to set it up for sound as well.
#2 ·
You can use either an 8 or 9 pin decoder.
WHICH you use depends on what kind of connector you have on the loco.
Does it have an 8-pin socket?
Or... does it have a 9-pin socket (with a "dummy board" plugged into it)?
Some engines might have both.
If you're not sure, take a GOOD pic (well-lighted with detail) that shows the light board on the engine. Someone will advise.
Hmmmm...
I -think- the Athearn SD-40 might have a "pop-off" dynamic brake housing on the top of the hood. This allows you to take off the housing, install a decoder, and put the housing back on without disassembling further.
Again, depends on WHICH version of the SD-40 you have (there are several).
Here's a picture of a 9-pin Digitrax decoder mounted to an 8-pin harness.
You can see the 8-pin connector.
The red arrow points to where the decoder is connected to the harness.
Remove the harness, and there are 9 pins.
The SD-40 may have a "dummy board" plugged into the 9-pin socket.
To install a 9-pin decoder, remove the dummy board and plug in the decoder.
BE CAREFUL -- you might have to cut away a small amount of the insulating plastic to get it to fit (the blue stuff in the pic). This won't hurt anything.
ALSO IMPORTANT:
On a loco with two decoder ports, you want to use ONLY ONE AT A TIME.
Don't plug an 8-pin decoder in unless you REMOVE the dummy board in the 9-pin slot.
Otherwise, you could burn out the decoder!
#5 · (Edited)
Looking at the pic above, that's a 9-pin port with a "dummy plug" inserted into it.
You have to remove the dummy plug and plug in the 9-pin decoder.
You'll need a small flat-blade screwdriver (I said, "small") to GENTLY pry the dummy plug off.
DO NOT put anything into the 8-pin port once you have the 9-pin decoder plugged in! (you can see the 8-pin port in the pic above, too)
