Great stuff. I really appreciate it. Millstone Mike what are the dimensions of that layout? And, what software did you use. My goal is for my layout to be about 60% complex as yours (by sight) - 8 feet long and 5 feet wide.
Thanks again,
Andrew
18' x 4.25' with an extra 2.5' at the dogleg. The program is SCARM and you can download it
here. It's license is free for the first 100 pieces of track (and any other objects). Mostly operates like Microsoft apps, point and click, but with a few quirks. You get used to it. It does have a database of all the various track types from prewar O to Gargraves, Atlas, and on and on.
I will be using
these (pictured) to run the main feeds under the table, take off a power drop to the topside and then continuing the main feed if it's a daisy chain. They'll screw to the underside and then attaching wire is a snap.
Supposedly good down to 12 AWG but I've seen other spec.'s that may limit it to 14 AWG. I'm thinking house electrical wiring (e.x., Romex) for the main feeds and then 18 AWG for the short drops to the track's lock-ons. I'm hoping it will do 12 AWG as I have 100' of it doing nothing in the garage. Roughly $1 each but you have to wait for the "slow boat from China" to get them. I have a couple on order to test them out and will post results.
