Bachmann EZ Track Switch/Turnout Problem
5.1K views 8 replies 6 participants last post by  Mr.Buchholz
#1 · (Edited)
It has been a while since I used it, but I had an issue with certain cars derailing over a Bachmann EZ switch track.
Has anyone experienced this?
I have cars with both Kadee and hook/horn couplers. I suspect that possibly the metal piece on the Kadee that extends beneath (not sure what it is called) may be too low on some cars and hits part of the track. But this is just a guess.
Any ideas?
#2 ·
Check that the coupler-pin will be ~1/32 inch (or more) above the rail-top while placing a slight downward pressure on the end of the coupler. The pressure is to place the coupler at the low point of its up/down movement. If you do not have a coupler-gage, use a ~1/32 inch thick piece of a flat-something and tape it across the rail-tops. This is what I had to do before I could successfully run long trains across a switch at the bottom of a long down-grade.
#7 ·
Shock
If the suggestions offered do not solve your derailing
try this:
Run the cars that derail as slow as your train will go
thru the suspect turnouts. Have a strong light on
the wheels. Get down close and watch the wheels.
When you see one LIFT...STOP.
That is where the problem is. See what is different
about the points, frogs, or joiners there. You may
have to do this more than once to get it.
#9 ·
My whole layout is based on EZ track, and there is the odd time that the cars derail over the switches. Make sure that the height is the same on the couplers of ever piece of rolling stock you have on the tracks. Also, periodically check your track connections. EZ track has a habit of loosening at random.
-J.
