1 - 16 of 16 Posts
Hi there,
I have a Bachmann Spectrum GP-30 Diesel, EMD Demo #5639 - item # 41-0821-L7 which was purchased on Ebay. It needs a respray, and also the replacement of missing hand rails, part #s 76005-00D01 (2 off), 76005-00D02, 76005-00D03, 76005-00D04, 76005-00D05. I have looked on the Bachmann spare parts listing but it appears they are no longer available.
Does anyone know where i can get these, (I'm in Australia), either in Australia or USA?
Any help would be appreciated.
Thanks,
Ian
If you've been on the Bachmann parts site then I guess you've seen the replacement shells (with hand rails) for $22.76. That may be your best bet.
Thanks, I had seen that, but as I only paid $AU51.50 on Ebay, I don't think it is cost effective. I am toying with the idea of making them from either brass wire or Evergreen plastic.
Ian
A couple of options:
  • use Athearn "Blue-Box" short & medium stanchions with .015 or .019 brass wire to make your own.
  • use Smokey Valley RR Products Kit #6 "Handrails and Stanchions for GP30", if you can find them.
Dan
I'd have to check but the older handrails from pre-spectrum Bachmann and Lionel GP 30 might fit. You can often find one of those old pancake motor models very affordably.
Let me know if you'd like and I can check. No guarantees but I might still have the cheap version to compare to my Spectrum.
Discussion Starter · #6 ·
Thanks for your reply.
I'm waiting for the purchase to arrive. When it does, I will photograph it and place it on this post. Apparently someone painted it black and from the photos on ebay it's a "crap" job. I will be stripping and repainting in my layout custom livery, so not sure how old it is.
Ian
Discussion Starter · #7 · (Edited)
Well, the purchase has arrived. I will have to remove the shell - if I can find out how it comes off. (Hint, hint) the screw underneath only holds the fuel take on. I think I will have to lever it off.
Not sure what motor it is yet, but I'm certain it's not a pancake motor, going by the info sheet that came with it.
Font Parallel Triangle Rectangle Art
Bumper Rectangle Gadget Technology Font
Camera accessory Camera Digital camera Reflex camera Cameras & optics
Motor vehicle Vehicle Rectangle Rolling Tints and shades
Train Motor vehicle Vehicle Rolling Rolling stock
Train Rolling stock Rolling Wood Vehicle
Yellow Font Drink Alcoholic beverage Circle
Ian.
Whoa, what a stinker...I can smell it all the way up to the States. I have one, it is a fine runner. When I purchased it, the front and rear railings were missing. I found that Athearn GP railings found in a scrap box fit perfectly and were quite sturdy.
Definitely not a pancake, those were only on Lionel and pre spectrum Bachmann versions. Looks like a standard can motor and flywheels. If it's in good shape it should be a good runner.
Looks like someone decided to messily spray black over what was probably a pretty cool EMD demonstrator scheme.
Once you get the shell off, I'd give it a long bath in Purple power or some other plastic safe paint stripping solution.
As for removing the body, after you take off the fuel tanks you should be able to pry the sides just a bit to get the body over the long rectangular mounting lugs. You can see the lugs over the air tanks.
Discussion Starter · #11 ·
I have a very good plastic safe paint stripper, it's called Dettol, an antiseptic, been around in Australia "since Adam was a boy". I've already stripped and repainted one loco shell, with another soaking in it, then this one to do.
I have attached a photo with the fuel tank cover removed. Does that give you enough indication as to what motor is installed? Hopefully I can get the shell off later today. Are they any complications in adding a DCC decoder, as I have read that the design of the chassis can cause problems?
Automotive tire Bumper Automotive exterior Auto part Cable
Thanks for your help - so far! :)
Ian.
Discussion Starter · #12 · (Edited)
Ok, managed to get the shell off the chassis. Now I can prep it for painting.
One other thing, and I don't think it's off topic, as it technically has to do with the shell being off the chassis, how do I go about about adding a decoder. At this stage just a normal Digitrax decoder. I'm NOT intending to add sound any time soon. Photo with the shell off attached. Being a split chassis I thought I'd better ask before dismantling.
Wood Automotive exterior Rectangle Auto part Metal
Circuit component Rectangle Office equipment Electronic component Electronic device
Ian.
EDIT.
I managed to source Athearn handrails from Arrow Hobby in Carlsbad, Caliifornia. Have emailed them for some details.
The main thing you must do, is to electrically isolate the motor from the split frame. There is enough room between the frames so that you can run the motor wires up through. You will need to mill out a space for the decoder, I would recommend using a N-Scale one (less milling).
I have done a Bachmann F40PH, basically the same procedure. I deleted the lighting board and hardwired in LED's for the lights (Headlights + Strobes).
1 - 16 of 16 Posts
