Okay. Which glue/adhesive are you folks using these days? I'd also like to use said glue to create loads for hopper, gondola, tender, etc.
Tia
Scott
Tia
Scott
I use that too, tube and spray. How has it worked out for Ballast?I recently started using a product called E6000 in a gentle pump spray bottle. Great stuff and has a very tight spray pattern and doesn't blow your ballast around.
Despite MichaelE's answer, I would pre-wet the ballast. Otherwise you end up with a hard crust over loose ballast, which isn't a good thing.Regarding the E6000 for ballast, do you use only it directly or do you prewet the ballast? After spraying assume you immediately clean the rail heads?
