Good job! But I see USAF on the wall. SAC, ATC and?Grass or ballast first. I don't think it really matters one way or another. I've done it both ways with no problems with either one first...or last.
My current yard project was grass first only because it's faster than ballast and easier to do a good job with a minimal amount of fuss.
Ballasting is time consuming and tedious work and must be manipulated to get it looking good.
In my opinion, anything can wait a long time. It's not a race!I'm using a method my brother used on O tinplate.
Paint the roadbed gray before laying track, ballasting can wait a long time if you don't see cork!
As with everything else in this hobby, there is no right answer. Do if first, do in last, do it at the same time.I'm just in the process of making a small layout 8' x 4.5'. and have nearly chose configuration. I'll be glueing track to cork road bed, my question is do I ballast before or after laying scenery (grass etc)?
ballast and weather the rail before you go to scenery work, you will have less chance to disturb the trees or buildings or whatever you mean by scenery.I'm just in the process of making a small layout 8' x 4.5'. and have nearly chose configuration. I'll be glueing track to cork road bed, my question is do I ballast before or after laying scenery (grass etc)?
I always used distilled water mixed with the white glue thin enough where the mixture would flow through an eye dropper. This also had a small amount of Dawn dish soap added.Thank you for all the replies, I tried mixing an amount of isopropynal with my white glue and ended up with a mixture like lumpy porridge . Back to the drawing board.
Same here. 50/50 white glue/water. I use the isopropyl alcohol straight out of the bottle.I always used distilled water mixed with the white glue thin enough where the mixture would flow through an eye dropper. This also had a small amount of Dawn dish soap added.
I only used the alcohol/water mix to spray on the dry ballast before adding the glue solution. The ballast needs to be wet thoroughly.
Everyone seems to have their own method.
