1 - 20 of 33 Posts
Yes, lol that is more then a basket case. :D
He must have snagged that while fishing?
Needs a little TLC huh? :D(y)
The shell is junk iam looking on ebay for one.
The horns are still good. Save them. :)
You could use it If you had a place to set it up as a crash scene, or put it in a scrapyard on your layout, hang it off a crane car.
Or send it to the aka The Epoxy man, (T-man), he would epoxy it to look like new. :)
  • Like
Reactions: flyernut
I have a large tub with approx. 50 shells, but do you think I can find it???
Discussion Starter · #17 ·
Bought a shell from Doug Peck last night and decal painted Frame and weight replaced upper and lower fingers cleaned drum bench tested works good still have to get the right truck chassis for rear u style.
Discussion Starter · #18 ·
New shell came in today from Doug Peck put decals on here is a couple pics. Also hooked up 4 link couple tanker cars having a hard time staying on to 370 switcher any suggestions would appreciate it. Thanks Al
Train Vehicle Rolling stock Wheel Plant
Train Automotive lighting Rolling Rolling stock Railway
Train Automotive lighting Vehicle Motor vehicle Hood
It looks good. The coupler bars appear to be at the correct height. Make sure the link couplers on the car that couples to the 370 are as low as you can set them and not have them underrun the bar. If they still uncouple it may be necessary to use a file to back cut the coupler.
1 - 20 of 33 Posts
