My grandson had a 20+ year old plastic battery powered train. The control was an IR system no longer worked. The train has two circuits; one for bell and whistle and the other for motive power. Each circuit is powered by 3 "c" cell batteries (4.5 volt). I stripped out the old control circuit board and purchased a simple remote controlled 12 Volt 4 relay circuit board. The 4.5 volts would not power the relays, so I put a 9 volt battery for powering the control board. I wired it all up, plugged the tender (holds batteries and control board) to the engine and it runs great. The 12 volt board has 4 circuits so I can run bell and whistle and motive power. I am having a problem with traction on the engine. May need to add some weight. The wheels spin just trying to pull the tender.
It was a very fun project and utilizing this little 12 volt relay board with remote control is giving me lots of ideas. I do need to figure how to reverse the train. Any ideas??
