1 - 11 of 11 Posts
I'm thinking of creating a new layout with a semi modular design so it would be easier to disassemble and reassemble when we move. It would be some have 4 x 4 and 2 x 4 sections. Homosote as the top surface. It would not be attached but just sitting on the frame. I have an idea in mind how I want to do it, but the only part I'm not sure of is how to brace corners to keep it sturdy. On my current layout I screwed some 1 x 2 material from the legs to the top rails. I'm trying to figure out something that would be a little easier to take apart and put back together or even a better idea for the corner legs.
You can still use the 1x2 angle braces. Simply attach them with carriage bolts and wing nuts so they're easy to remove.
Stumpy, I don't think those type braces are going to give me the lateral stability that is needed, will they? Have you used them? I can see where they would help hold the leg to the frame. but I'm not sure they would provide lateral stability.
Using wing nuts - good idea.
I have and they do. Years ago I built a "temporary" L-shaped desk using them and it's still going strong. Granted, they won't provide as much stability or withstand a swift kick to the leg as well as a longer, traditional brace.
Carriage bolts and wing nuts are a good idea. Use two at each attachment point.
Dave
My room size HO layout was entirely supported by modules of various sizes and shapes
bolted together. The modules were constructed as frames using 1 X 4" lumber screwed
together. I used the same 1 X 4s screwed together in a L shape for the legs. These
are bolted in the frame corners. They provide all the stability you need.
Homasote is a very desireable product to use as the 'table top' for your layout.
It is sturdy, yet you can push 'nails' or whatever into it and they will hold steady.
But, I would suggest that you 'anchor' the top with a 'few' screws. As you can
imagine such a layout can easily be taken apart and moved, or rearranged to
a different configuration.
Discussion Starter · #7 ·
Stumpy, I'm can't quite seem to picture how those brackets would be used. Do you have a picture of how you did it?
The temporary desk isn't with me any more. I'll see if I can get some pics taken... or try to remember exactly how I used them. :oops:
My bad Dave. I used those brackets between the legs and the desk top. The desk top was screwed down to the top band. The legs were screwed to the top band. Since I didn't want to use stretchers between the legs I installed the corner braces for extra leg support.
Discussion Starter · #11 ·
Interesting idea with the folding legs. I'm not going to be taking up and down a lot. I'm looking for something that will make it easier to take apart and move maybe only 1 time or 2. But I may be able to adapt that for my use.
1 - 11 of 11 Posts
