1 - 9 of 9 Posts
Long story short:
The diecast chassis of a 650 New Haven Coach has enough of a sway from one end to the other that I can't put chassis pins in.
Never had to straighten a diecast anything, am thinking it may break like my pop metal toys of long ago.
Gentle pressure?
Hair dryer heat and gentle pressure?
Propane torch and gentle pressure?
Oven ? temp and gentle pressure?
Cutting torch and gentle pressure?
Don't bother find another chassis?
I anxiously await the sage's answer.
Thanks
I use the propane torch and slow bend method. I've fixed many cabs doing it this way with no damage. Slowly heat and slowly bend.
I straightened a bad bent cab roof a couple weeks ago. One corner bent near 90*. I cut the intended bow of roof in a block of wood. Had to put a strip from tin can to keep the bad bent corner from gouging into the block. Clamped till tight with some pressure. Tightened a little bit everyday for about 10 days. Came out pretty good. I need to cut another mold block to finish but it's so close you won't see it unless is pointed out.
I did this without heat. But heat would be better. Mainly light pressure over several days adjusted daily.
Mopac, didn't drop it the first time. bought it that way cheap. Lionel Legacy for $100. and change. ;) ;) Yes, I was happy with the outcome. Didn't know if I could get it back that far without breaking. Turned out didn't even crack the paint.
Wow, thanks for all the responses gentlemen!
Cole226 nice work! I will add patience to the heat and gentle pressure plan.
I have used my acetylene torch set on VERY low heat and gentle vise pressure. I learned that torch technique repairing car radiators which have 2-3 thousands thin copper fins and equally thin brass tanks back when those kinds of radiators were in vehicles instead of today's aluminum and plastic types. Maybe a good quality heat gun would work with slow vise pressure. I have a commercial grade heat gun that has different temp setting similar to what GRJ mentioned but never tried it on those frames.
Cole226, that is a good job of bending that roof. Looks good and didn't even crack the paint.
Kenny
1 - 9 of 9 Posts
