a new channel devoted to the propeller powered rail car, will be documenting all of my experiments on this channel BENZ AERO CAR...
Could use a simple resistor value (Edit and diode) based on standard running voltage.Hello Ben. Just a thought here. Since your Aero Car now has DC voltage available, via the rectifier, Why not add a pair of them 3vdc spot lights to your AERO CAR. Of course a voltage drop circuit would have to be figured out & assembled. As I remember the battery pack for the Spot Lights has a power input jack. Be the first to have an air powered spotlight engine/car.
LATER
whats the point, the rectifier i am using was 3 bucks. a simple resistor would work, for now i am concentrating on building the car lighting can come later.What about something like this
https://www.amazon.com/SMAKN®-Conve...vdc+ac+to+dc+converter&qid=1577758428&sr=8-13
and a Bluerail board?
You could control the prop and some lights from the board and it would run on any track - conventional or constant voltage, AC or DC. Control it from your phone (yeah, it's neat).whats the point, the rectifier i am using was 3 bucks. a simple resistor would work, for now i am concentrating on building the car lighting can come later.
