best glue and applicator for fine gluing
1 reading
1.9K views 6 replies 7 participants last post by  D&J Railroad
#1 ·
I'm building micro engineering bridge and using a ambroid proweld with a syringe is there a glue I can buy that comes with a needle type applicator ? The syringe works but sometimes it sprays out too much pain in the ....
Thanks
#2 ·
Neil
I have a workbench full of every kind of glue but lately
I've been using the Harbor Freight version of Super Glue
GEL. I use a toothpick to apply it. You have only a few
seconds to make adjustments then it is set and you can
continue working.
The reason for Harbor Freight. Their glue is a fraction
of the cost of Super Glue brand. They sell packages of
several tubes for only 2 or 3 $. Be sure to get the GEL
type. It is easier to control the application.
#5 ·
I use Gorilla Super Glue, it is the only type that I have found that the tip never gets plugged.
It is also not quite gel but is thick enough to not run.
I only squeeze out a small amount on a scrap piece of what ever I have laying around and apply it with a tool that I made. The tool is just a small wire .020 that is glued into a small wooden handle.
For thin glue such as what I would use on styrene I use the Flex-I-File #7000 – Touch-N-Flow System which works great.
#6 ·
There are all kinds of applicator tools available. Here's Micromark's list of them:
http://www.micromark.com/SearchResult.aspx?deptIdFilter=0&searchPhrase=applicator
Personally, I like the applicator tips. They actually fit on a wide variety of bottles. And because any time Micromark comes up, someone feels compelled to gripe about their prices, I will launch a pre-emptive strike: This is not a purchasing recommendation but an illustration of what's available. If you can find a better price, by all means buy there.
#7 ·
I would second what JamesBC said about putting a small dab of the glue on scrap material then dipping a toothpick into it and applying it that way. I use the tip of an Exacto knife. For the bigger jobs, I apply it directly from the bottle or tube then spread it with the Exacto knife. Using a syringe may cause problems if you don't clear the syringe tube after each use.
