1 - 16 of 16 Posts
Hopper-palooza
H2a's for the 100-car coal drag.
A six-pack (two are shown). All done similarly.
I'm partial to the heap-shield style, so some Tangent L&N PS-3's are in the drag as well.
Mostly airbrushed.
Transport Train Railroad car Vehicle freight car
Transport Railroad car Train freight car Vehicle
Do you remove the trucks and weather them separately, or are they done in place on the car? I assume the wheels are removed before painting. Do you also add weathering to the bottom of the cars, or just focus on the sides where the weathering is visible?
Discussion Starter · #9 ·
I always do truckframes & wheels separately.
I don't always want filthy trucks, so I'll occasionally just 'dust' them with a gray or brown color, and drybrush for 'rust'.
Wheelsets are tricky... you can't allow any paint on treads or axle points, so DullCote sealing is essentially a no-no.
Underbodies are done (within reason) to match.
Discussion Starter · #10 ·
Are the coal loads factory made or custom?
The coal loads are supplied with the cars.
The early BLI six-pack production run came with three different coal profiles... Two each of 3-heap, 2-heap, and center-heap.
The 2 & 3-heap are shown.
I believe later production models only come with two shapes.
They look pretty good for factory loads. I occasionally make some loads for a friend who has a hobby shop, and I use the fine Black Beauty, which in O scale is the size of Chestnut, and in HO, closely represents Egg.
Discussion Starter · #12 ·
Actually, I don't think the BLI loads are very realistic... nowhere near dark enough, and no sparkle.
Here's two models with resin JWD "E-Z FIT" loads. They look like the real thing. These two particular loads are 'coarse' (or egg).
Transport Vehicle Railroad car Rolling stock Locomotive
Transport Railroad car freight car Train Rolling stock
From the photo they look pretty good, better then some of the O gauge plastic molded ones I've seen. This is an O gauge load I made for one of my 2 bay hoppers.
Transport Train Railroad car Rolling stock Railway
The grime on the cars sure does match your ballast. Very nice work!
Maybe you could give those coal loads a light coat of gloss black. That would darken them up and add some sparkle at the same time.
A clear coat may work too. When I make my loads, I use a commercial water base urethane floor finish in a spray bottle. The Black Beauty has the sparkle of coal, and the finish holds the load together, and seals the finish. It could also be used as a coke load.
1 - 16 of 16 Posts
