what are blocks?
also how would you wire them?
Thanks
Ron
Thanks
Ron
I have a reversing loop, if I do not change the direction correctly. the train will not advance on the the next block. it just jumps back and forth. not good.. BUT the direction has to be the same when traveling from one block to the other.
Southern I like your style.
Do you have to islolate the inner switches. I would link them with the outside switch. Why isolate a single switch?
ok this is all stuff that bcame with the used set-up that I bought.
I have plastic insulators,a few,2 transformers and 2 selector's like this.
what I don't understand yet is the plastic insulators,how doe's power go thur them to run a train?
