1 - 20 of 20 Posts
Sure looks like the crap is going to hit the fan for the Boeing Co. If it is proven that Boeing was well aware of the issues before the plane entered service some folks need to be heading to the slammer.
Bill
airbus had that problem with the frozen pitot tubes. i think it's still being fought in the courts. same kind of thing in my mind.
Southwest Airlines, the launch customer, took delivery of its first 737 MAX on August 29, 2017. Boeing planned to deliver at least 50 to 75 aircraft in 2017, 10–15% of the more than 500 737s to be delivered in the year.
After one year of service, 130 MAXs had been delivered to 28 customers, logging over 41,000 flights in 118,000 hours and flying over 6.5 million passengers. flydubai observed 15% more efficiency than the NG, more than the 14% promised, and dependability reached 99.4%.
Makes me wonder. How did they manage all this before some pilot couldn't fly the plane.
Software ? How many years has Microsoft been working at it and still can't get it right. :D
It's not that they couldn't fly the plane, it's that they forgot to fly the plane.
Had they turned off the system and disengaged the A/P (button on control yoke) they likely would have regained control of the aircraft, stabilized it, and re-engaged the A/P to continue the flight.
But I wasn't there to know exactly what went on in those cockpits.
Except to say they forgot to fly the plane.
I read the article in the NYT Magazine, which makes me wonder how much the FAA is to blame, too. A real screw up all around.
Truthfully, there aren't nearly enough FAA people to actually truly understand the complex systems in a modern aircraft.
A little example. I was the project engineer on a black box called the EDM for the JPATS military trainer. The box handled fuel gauging and balancing, engine instrumentation, and even nose-wheel steering. Basically, all the stuff that was left over from other OEM boxes we stuffed into that one. When all the paperwork was done, we had two legal sized boxes of paper for the certification and TSO. We went up to the FAA in Long Island and they "reviewed" the paperwork and we got the TSO in one day. What do you think the chances are that they actually read a significant part of the 100+ pounds of paper we brought?
New companies and/or new technology (think lithium batteries, composite constructions, etc.) are carefully scrutinized and all their documentation is thoroughly reviewed. If you're an established aerospace firm, and you've had a number of successful products without significant issues at any stage, the process is considerably streamlined.
From what I have read the biggest issue with this aircraft is too big engines and the placement of them created an aircraft that has a larger potential to stall so the control system was meant to overcome this since there was a huge cost savings in keeping the current airframe. But, like a front engine Corvette, there has to be a significant amount of engineering with software and control systems to make them operate as a normal driver or pilot is accustomed to...….the system flaw of an overriding nosedive was not expected to result in crashes.
Well, I think that's an oversimplification of the issues. However, suffice to say that the different engines and placement does change the handling characteristics of the airplane. This is hardly the first aircraft that has had an automated system kick in and cause a crash, just the latest example.
Larger nacelles on the MAX placed the front of the engine more forward than in previous 737s. This resulted in a tendency for the nose to pitch up more than previous models. In order for the plane to behave more like its predecessor the 737NG, they installed the MCAS system, which would respond to extreme pitch angles by pushing the nose down. However, the system had issues that were either known and not dealt with, or unknown until the plane was in service. I'm not going to speculate on which of those occurred.
One issue was only one angle of attack sensor, if that fails, the MCAS system may have a problem knowing what to do. Apparently, one of the fixes is to install two angle of attack sensors and do comparisons. If they don't agree, they'll automatically turn off the MCAS to avoid false maneuvering cues. Also, they are enhancing the ability of the pilot to simply override the automatic controls with yoke inputs, apparently the first generation was a bit too aggressive.
I read that. Seems interesting that they only had one to begin with. Redundancy is built-in to most flight controls, why not this one?
Turning off MCAS was apparently not straightforward. And the training required to fully understand the system was not well implemented.
Hard to say, those are mechanical devices that have failed in the past, I believe at least one accident has been blamed on one failing. That's besides this pair of accidents.
Actually, there was no training on the MCAS, they were trying to "keep it simple". They were assuming that the automated system would only kick in when needed. Probably not the smartest decision that was ever made.
Wikipedia is not normally my first source of information regarding aviation matters, but information seems to be scarce on exactly how this system operates and on what dependancies and what depends on the system.
Whomever wrote this page appears to know what he's talking about, or at least has the appearance of that.
This gave me a better understanding of how this system operates. Heck, the Boeing Pilots Operating Manual doesn't even describe this system.
In the old days, IE, the Boeing 727-200 and 737-200, the Sperry SP-50 and SP-150 was set up so that if there was input to the control column or yoke, the A/P would completely disengage. There were also Stab Cutout switches on the throttle housing that would control a runaway stab trim condition in case of screw jack failure or switch failure.
It was a simple but effective system that worked. It's too bad that computerized flight control systems have mucked up the simplest things.
They could have retained the original engine position by simply building the landing gear taller and moving it farther outboard, or as with the CFM65 engine fan shroud, flatten it at the bottom and not raise the gear so much.
Instead of aerodynamically fixing this error, they try to band-aid it with computer software. It's not a B-2.
https://en.wikipedia.org/wiki/Maneuvering_Characteristics_Augmentation_System
I resorted to Wikipedia because there was no other reasonable source of information on the system. Like you say, it at least appeared that the guy that wrote that had some knowledge of the specific systems and aircraft.
The problem with making the landing gear taller would have been a major modification of the fuselage, that would have been costly I suspect. Then there's the issue with mating up with jetways, they have a limited amount of up/down travel.
I'm sure the engine placement was the cheapest way to fit the new engines to the airframe.
The biggest mystery, at least to me, is why they depended on a single AOA sensor for such a flight critical function. It's also somewhat of a mystery how it passed the scrutiny of the FAA, I sure never got anything that brazen past them!
You can bet your bippie that the future holds more FAA scrutiny of Boeing until they clean up their act!
I agree. On the aircraft I mentioned there was an instrument comparitor mounted above the ADI that compared the various inputs from the flight data computer. If something didn't agree within so many degrees, knots, feet, and so on, one of the comparitor lights would illuminate alerting you to what the problem could be and where to look for it.
How could Boeing not build in a comparitor that used both AOA sensors is beyond me and beyond stupid.
Now they 'get it' though. Duh.
1 - 20 of 20 Posts
